k20 timing marks?
Old Nov 10, 2005 | 04:09 PM
high_revs's Avatar
Default k20 timing marks?
how would i go about putting the timing chain? any1 have the timing marks or the cams, and crank? thanx
Old Nov 10, 2005 | 10:00 PM
high_revs's Avatar
up
Old Nov 11, 2005 | 07:17 AM
high_revs's Avatar
some1 has to have info on this
Old Nov 11, 2005 | 03:34 PM
high_revs's Avatar
bump for info
Old Nov 11, 2005 | 06:11 PM
Tom5's Avatar
Default Re: (SB tuning)
Timing chaing doesnt really matter. Lining up the cams with the first and fourth cylinders is the fun part.. just make sure the chain is tight between the intake cam and the crank first. meaning start with the chain tight on the crank then tight on the intake cam, then tight on the exhaust cam. The rest of the slack should be after the exhaust cam because thats where the auto tensioner is for the chain. hope that helps somehow.
Old Nov 11, 2005 | 11:49 PM
high_revs's Avatar
yes, it helps a lot thank you, but do you have any pictures of the alignment marks
Old Nov 12, 2005 | 07:29 AM
high_revs's Avatar
bump
Old Nov 12, 2005 | 10:11 PM
high_revs's Avatar
uuuuuuup
Old Nov 13, 2005 | 08:11 AM
high_revs's Avatar
up for timing marks
Old Nov 13, 2005 | 10:05 AM
Tom5's Avatar
Nah, I dont have any pics but there should be 2 marks on each cam sprocket. They should be 90 degrees apart. 2 of them should be aiming at each other and parallel with the head. This will make the other 2 marks aim straight up.
Old Nov 13, 2005 | 10:25 AM
high_revs's Avatar
cool, basically like every other dual cam honda motor, what about crank, similar to b, h, d series?
Old Nov 13, 2005 | 01:56 PM
Tom5's Avatar
yep.....good luck with whatever
Aqueous5
Mar 5, 2008 09:15 AM
00Red_SiR
Feb 10, 2007 06:49 AM
b16ahybrid
Feb 1, 2006 04:56 AM
ITRfaithful
Oct 28, 2003 09:58 PM
Dokta
Aug 7, 2002 07:07 PM
