I searched... ideal welder for turbo exhaust manifold
Old Nov 10, 2005 | 02:36 PM
CarbonCreations's Avatar
Default I searched... ideal welder for turbo exhaust manifold
MIG or TIG? Argon?
Don't need stainless steal at this point.. just regular 16g mild steel.
Thanks
Old Nov 10, 2005 | 02:46 PM
ManBearPig4silly's Avatar
dont use 16g mild steel. use sch 10/40 weld els and tig weld them.
Old Nov 10, 2005 | 02:47 PM
Default Re: (I4sillypwr)
ok schedule 40 it is.
and a MIG welder wont work? elaborate for my little brain please
Old Nov 10, 2005 | 03:01 PM
mig will work (bailhatch makes them) but tig is better. Simply read a little bit in here and you will learn a lot.
Old Nov 10, 2005 | 04:49 PM
Bailhatch's Avatar
I use a big ol Miller TIG now ...but yes mig will work fine if you cut a deep chamfer and get a good technique (gravity is your friend).
Old Nov 10, 2005 | 05:05 PM
Default Re: (Bailhatch)
Great to hear, all I needed to know
MIG for time being, TIG if I find the need to drop some serious coinage
Old Nov 11, 2005 | 05:49 AM
oldskoolracer's Avatar
CHAMFER,??????? PLEASE EXPLAIN
I'M WANTING TO BUY A WELDER SO I CAN TRY TO FABRICATE MY MANIFOLDS
Old Nov 11, 2005 | 07:11 AM
aarontrini85's Avatar
Default Re: (oldskoolracer)
cut a little edge in the metal so you can weld in that like wedge o say this represents your flange______ and this is the piping for the manifold |
_______|_____| _____
if the pipe wasnt chanfered that is what it would look lik sitting agains the flange
what you want is
_________\________/__
see the little edge there? its where you want your weld to be penatraiting
i cant spell lol but hope fully that helps
*edit* damn it it wont let show it how i want it to but hope fully you can get the point lol *edit*
Old Nov 11, 2005 | 07:45 AM
weiRtech's Avatar
OG Fabricator
what is wrong with using 16g? schedule 10 is more than enough. sch 40 is just too heavy i find and it holds a lot of heat.
dwnthehatch
29
Jun 14, 2009 03:51 PM
G_moneydc2
Welding / Fabrication
Nov 13, 2005 05:28 PM
.David
23
Dec 5, 2004 06:32 AM
redboost10
Aug 31, 2004 11:55 PM
FOrSfEd
May 7, 2004 06:59 AM
