Gsr Block w/ 81.5 mm Bore. What size CTR pistons??
No. If your bore is actually 81.5mm you need 81.5 pistons not 81.25mm pistons. Take it to someone with a inside micrometer.
https://honda-tech.com/zerothread?id=1415277
so this is the wrong information for the block i bought.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kidd_drastic »</TD></TR><TR><TD CLASS="quote">I have a gsr block w/ 81.5 mm bore. i'm looking to get ctr pistons. Do i get the .25 oversized ctr pistons.</TD></TR></TABLE>
the info is right:
.020" or .5mm is the piston size the block was bored for.
therefore, you need .020 or .5mm pistons...easy as that. Just call me if you have any questions.
the info is right:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PURPLETERROR aka BIGMATT »</TD></TR><TR><TD CLASS="quote">you want the 84 mm pistons, just heat up the block first and hammer them in there</TD></TR></TABLE>
Ha ha. Made my day.
Ha ha. Made my day.
