O2 sensor acting up?
Old Mar 10, 2002 | 02:52 PM
EFSiR's Avatar
Default O2 sensor acting up?
WHy would ECU throw a O2 code only when decelerating with TB closed with RPM dropping from 3K to 1K?
Code does not appear under any throttle application... O2 sensor is new.
89CRX 1G B16
JDM PW0
Code 2 stored, changing plugs around on the 2 oxygen sensors still generates code 2
O2 sensors are new
TIA
Old Mar 10, 2002 | 02:55 PM
Zeus Zore's Avatar
Default Re: O2 sensor acting up? (EFSiR)
bad new o2 sensor !! i have bought one cuase i thougt that mine was broken.. and when doing over 170 KM/t = ( some 110 MPH) it came with a code on the sensor !! plug the old one in... and off we go
is it a original (made by honda) 02 sensor ??!
Old Mar 10, 2002 | 02:58 PM
EFSiR's Avatar
It's NGK, OEM Shtuff. Both of the O2 sensors are brand spanking new.
What's weird is that switching the plugs on the O2 sensors still generates code 2!
This is driving me crazy.
Old Mar 10, 2002 | 04:42 PM
Zeus Zore's Avatar
Default Re: O2 sensor (EFSiR)
could you borrow one from a friend !!?? 2 try if it still does it !?! that would be the way !!cause if so !!! then you should look else where for the problem !!
Old Mar 11, 2002 | 12:51 PM
Perfectionist's Avatar
The code will set if the ECU sees no activity from the O2 sensor for a certain period of time. I would guess the O2 output is 'pinning' either rich or lean during the deceleration, and causing your code. Normally, the exhuast would be lean during decel. Why this would set a code in your case, I don't have any answers.
Old Mar 11, 2002 | 05:07 PM
EFSiR's Avatar
My guess is that it is rich. I have recently adjusted the TB voltage to be smack on at 0.45V with TB closed.
What is puzzling me is that if it is rich during deceleration, why don't two of the O2 sensor see it as that?
I have tried second ECU (JDM PR3), same result.
Old Mar 12, 2002 | 02:33 AM
samiam's Avatar
Check for continuity in the wiring harness w/ ohmeter (dvom) if continuity is ok try using shielded wire as a o2 sensor wire. You may be getting RFI interference.
[Modified by samiam, 3:34 AM 3/12/2002]
efhatch1991
Jan 26, 2013 07:05 PM
accord2civic2prelude
Dec 12, 2009 03:35 PM
Bossup!
Sep 9, 2009 07:35 PM
SwiftTypeR
Feb 26, 2007 01:20 PM
civichybridb16a
Jul 26, 2001 04:51 PM
