rusted valves in head - d16z6 head
Old Nov 10, 2005 | 10:40 AM
headhunter's Avatar
Default rusted valves in head - d16z6 head
i have a d16z6 motor that i'm planning on installing into my car. while doing a closer inspection, i noticed that the valves in the head had some rust building on it due to the motor sitting in a garage for about 3 years or more. It might just be suface rust, its not extremely rusted . Is it safe to start this motor up or will i need to get new valves?
Old Nov 10, 2005 | 10:45 AM
CRX Toad's Avatar
Default Re: rusted valves in head - d16z6 head (headhunter)
For goodness sakes clean them up first and then inspect them. If you start your car as is with that head you are going to choke/kill your car.
Old Nov 10, 2005 | 10:47 AM
g-ride-si's Avatar
an sos pad should fix that. it would have to be sitting quite a while to rust any more than surface rust.
Old Nov 10, 2005 | 10:57 AM
headhunter's Avatar
well i dont plan on modding the engine, i just need it to run and get from point a to b. i am viewing the rusted valves from the intake manifold ports on the head. when i pulled off the head, the valves from there looked fine(under the head). its when i was about to install the intake manifold is when i discovered the rust. i really dont want to pull the valves, do you think i can sneak on by and just fire it up ?
Old Nov 10, 2005 | 11:02 AM
g-ride-si's Avatar
well not seeing the rust, i cant really say. if its just a small amount of surface rust (like dust), youll prolly be alright. but you dont want flakes of rust falling down onto your piston.
Old Nov 10, 2005 | 11:18 AM
headhunter's Avatar
i'm gonna take picture of it tonight and post, do you mind checking this thread later on and giving me your opinion?
Old Nov 10, 2005 | 11:34 AM
g-ride-si's Avatar
no prob.
goo_punch
Nov 1, 2015 02:54 PM
Hondamonster
May 31, 2007 05:43 PM
Sinner
May 22, 2005 06:36 PM
