400hp b16a, do i need to sleeve it?
probably a pretty mundane question so an answer would be better than a flame. im new to boost.
looking for 400 hp on pump gas. im guessing 18psi might get me there, 9.0:1CR, aftermarket pistons, rods. im sticking with the stock bore and stroke maybe .25 overbore at most, basically jstu wondering if i must sleeve it and what little helpful tidbits are nessicary ie. cam selection, compressor selection
Well im running a stock sleeved 81.5mm b16. On 18psi it makes 370whp with an sc61 on it. On 20-21 psi it makes 415whp. This is done on stock b16 cams, the bottom end consists of eagle rods, je 9.1 pistons .20 overbore, ge blockgaurd. I have sk2 valvetrain on the head and thats it. I dont think you need to sleeve it to make what im making. My engine builder/tuner does not sleeve a motor unless the person wants to make over 500whp, stock sleeves with the right tunning will last a long time on 400whp.
No. It is generally accepted here that stock b-series sleeves (excluding b20) will hold 400 whp and be fairly reliable, the tune is a VERY large factor here.
Reading comp maps...
https://honda-tech.com/zerothread?id=142398
https://honda-tech.com/zerothread?id=96443
Some good discusion wrt turbo efficiency....
https://honda-tech.com/zerothread?id=1055905
The faqs have a lot of useful info, how much boost you will need to reach your desired hp can be calculated for specific engines and compressors using the information in the links above. GL.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRXofPain »</TD></TR><TR><TD CLASS="quote">thanks. you guys are super helpful compared to other places ive been.
any other input? anyone making boost specific cams? </TD></TR></TABLE>
Skunk2, Blox, Crower and some other companies make turbo cams, but most people making good power are running on Honda cams. Either B16, GSR, Type R, CTR, etc.
people have made good power with ctr and itr cams and they are relatively inexpensive. I am using a set of crane stgII all motor cams in my engine, the specs are ver close to those of oem itr cams. Got em' at a really good price 2.
the.hamburglar
Sep 29, 2005 05:59 AM
B00STED Si
May 26, 2005 08:00 AM
MikeExt
Sep 18, 2003 03:58 AM
