loose e-brake
Old Nov 10, 2005 | 05:14 AM
hondamama7894's Avatar
Default loose e-brake
I'm having a problem with my emergency brake. The handle is extremely loose. It works, but it has alot of play in it. I'm not sure if something just needs to be adjusted or if theres something wrong with my rear braking system. Fluid level is fine, so its not that. Anyone know what this could be?
Old Nov 10, 2005 | 05:20 AM
tasco's Avatar
Default Re: loose e-brake (hondamama7894)
it sounds like your e-brake needs to be tightend
Old Nov 10, 2005 | 05:21 AM
shamoo's Avatar
Will you make something up for me please?
Default Re: loose e-brake (tasco)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tasco &raquo;</TD></TR><TR><TD CLASS="quote">it sounds like your e-brake needs to be tightend</TD></TR></TABLE>
Yup. The emergency brake works on a cable system, there is no fluid involved. Just pop off the center console by the e-brake and you can see exactly how to tighten it. It's self explanatory.
Old Nov 10, 2005 | 05:46 AM
Spoogen_1's Avatar
Default Re: loose e-brake (shamoo)
Take a gander. The big silver thingy works on a bolt and a spring. If u tighten the bolt the stiffer it gets. but dont quote me on that cuz i could be wrong
Old Nov 10, 2005 | 05:48 AM
Thanks for the help. I'll try it tonight, and see if that helps.
Old Nov 10, 2005 | 05:53 AM
shamoo's Avatar
Default Re: loose e-brake (Nexus131)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nexus131 &raquo;</TD></TR><TR><TD CLASS="quote">Take a gander. The big silver thingy works on a bolt and a spring. If u tighten the bolt the stiffer it gets. but dont quote me on that cuz i could be wrong</TD></TR></TABLE>
Well, I'm quoting you.
Because you are correct. Don't tighten it TOO much because a few turns will make a VERY loose handle into a pretty tight one.
duyfash0
12
Sep 5, 2007 04:02 PM
Tjames8864
Jan 25, 2007 04:59 PM
jacky599r
Jan 22, 2006 08:12 AM
lilman4o8
Jun 9, 2005 07:33 AM
sshaikh01
Apr 26, 2004 04:33 PM
