e brake loose
Old 01-25-2007, 01:42 PM
Tjames8864's Avatar
Default e brake loose
can anyone tell me how to tighten up my e brake...its really loose and barely works on hills anymore...thanks in advance
Old 01-25-2007, 01:45 PM
B18CivicEH2's Avatar
Default Re: e brake loose (Tjames8864)
remove the center console that covers the ebrake, you'll see an adjustment bolt where the 2 wires meet...just tighten it up...done..
Old 01-25-2007, 02:26 PM
norcalboy_abe's Avatar
is that handle thing the problem, or the parking brake itself?
Old 01-25-2007, 04:41 PM
Tjames8864's Avatar
Default Re: (norcalboy_abe)
idk when i pull it all the way up it barely holds my car in place
Old 01-25-2007, 04:45 PM
pdiggitydogg's Avatar
You need to jack up the rear of the car
Start the car
Press the brakes a few times (i like 10x, but thats more than enough)
THEN you can use the adjustment nut that is under the console.
If you dont do it this way...well...youre doing it wrong, and you will not be adjusting it properly.
As long as everything is working correctly, that procedure will take care of it.
Default Re: (Tjames8864)
yea...my car was doing something like it...i would usually have to pull the ebrake very high and hard to make it grip but still didnt grip hard enough...so i tighten up that bolt now it works great...i didnt jack up the car like ^^^ said and it still works and havent come across any problems...but hey, whats a little extra work thatll give the same results??
Old 01-25-2007, 04:51 PM
Its not the same result...
Trust me, if you do it the way its supposed to be done, your brakes will work much better - both parking and in general use.
Old 01-25-2007, 04:59 PM
Tjames8864's Avatar
Default Re: (pdiggitydogg)
yea thanks guys ill do it tomorrow and let ya know
ShadowDaisy82
Honda Civic (2001 - 2005)
05-09-2017 01:36 PM
duyfash0
12
09-05-2007 04:02 PM
lilman4o8
06-09-2005 07:33 AM
SoOHiGH
04-19-2005 04:04 AM
Clydsdal
09-15-2003 05:02 AM
Quick Reply: e brake loose
