Double Checking LS - GSR TRANNY SWAP
Old Nov 9, 2005 | 09:17 PM
eyece's Avatar
Default Double Checking LS - GSR TRANNY SWAP
Double checking a parts list if someone that knows could do this for me
GSR Hydro Tranny
Integra rear mount T-bracket for a manual car
Complete Shift Linkage
LS ECU - manual
Complete Pedal Assembly - clutch/brake/gas - check wrecking yard
Clutch master cylinder -
hard lines from clutch master cylinder to trasmission - i think it comes in two pieces
slave cylinder
manual flywheel b series
clutch of your choice 94-01 integra
transmission mount manual
frame mount from acura - connects to trans. mount -
this needs to be welded on and the old one cut off
Thats what I need for the swap to be complete correct? If I'm missin' anything if you could let me know it would help a lot It's going into an 01 LS
Old Nov 9, 2005 | 09:36 PM
blackdelslo's Avatar
Default Re: Double Checking LS - GSR TRANNY SWAP (eyece)
oil
Old Nov 10, 2005 | 05:28 AM
shamoo's Avatar
Will you make something up for me please?
Are you talking about an automatic to 5-speed conversion? If so, there are several posts on this as well as a few in the Integra FAQ.
There are a few in your list that can be taken off, as well as a few that you didn't mention.
00hatch4sale
Texas -OK -LA (Sales)
Dec 26, 2009 09:20 PM
eyece
Oct 9, 2005 09:57 AM
DA6righthand
Jan 8, 2004 10:19 PM
AznInvasion
Sep 12, 2003 06:19 PM
Mr.DC2TurBo
Mar 18, 2003 03:24 PM
