spoon headgasket with lsvtec setup valve clearance to close yes no?
Old Nov 9, 2005 | 06:19 PM
mamskater's Avatar
Default spoon headgasket with lsvtec setup valve clearance to close yes no?
If I use a spoon sports headgasket with my lsvtec setup is there enough valve clearance cut in the stock ls pistons to use the thinner headgasket with no problems?
Old Nov 9, 2005 | 07:25 PM
lohatch's Avatar
Default Re: spoon headgasket with lsvtec setup valve clearance to close yes no? (mamskater)
clay the engine and find out.
Old Nov 9, 2005 | 07:34 PM
SkankyEJ7's Avatar
Default Re: spoon headgasket with lsvtec setup valve clearance to close yes no? (lohatch)
you your using the stock pistons, then yes there will be, but you can clay the motor as well
Old Nov 9, 2005 | 07:53 PM
lohatch's Avatar
Default Re: spoon headgasket with lsvtec setup valve clearance to close yes no? (98ekhx)
if you are running larger cams, you will want to clay it anyways to find out your cam timing limitations.
BlueBallsSI
19
Jan 23, 2008 04:44 AM
capcon83
Nov 5, 2002 09:16 AM
B2FiNiTY
Apr 23, 2002 06:08 PM
VtecNit01
Jan 21, 2002 10:20 AM
