a lil pic of my tig welds, any comments?
Old Nov 9, 2005 | 04:19 PM
ccfab's Avatar
Default a lil pic of my tig welds, any comments?
i am open to constructive critisism as it is a key tool for improvement.,
the machine is a syncrowave 300 and im using 308 rod,, this was at 155a working the pedal.
thanks for looking.,
Old Nov 9, 2005 | 04:46 PM
Dragline's Avatar
Default Re: a lil pic of my tig welds, any comments? (ccfab)
Looks good, What are you doing to clean the metal before welding?
Old Nov 9, 2005 | 04:53 PM
ccfab's Avatar
Default Re: a lil pic of my tig welds, any comments? (dragline)
wire wheel. any suggestions on how to properly prep the metal??
ive noticeed some of my welds are a bit contaminated sometimes.
fishing for a few tips here
Old Nov 9, 2005 | 04:57 PM
Dragline's Avatar
I use acetone to prep the metal,it doesn't leave any residue.
Old Nov 9, 2005 | 04:58 PM
ccfab's Avatar
nice, good looking
Old Nov 9, 2005 | 05:05 PM
Dragline's Avatar
What is your gas set at also ? are you using a stainless steel wire brush?
Old Nov 9, 2005 | 05:07 PM
ccfab's Avatar
15 lbs
Old Nov 9, 2005 | 05:15 PM
fabrak8rX's Avatar
yep, acetone works, dupont makes a product called Pre-Sol, like acetone but a little less toxic.
looks good
Old Nov 9, 2005 | 05:16 PM
jon volk's Avatar
Default Re: a lil pic of my tig welds, any comments? (fabrak8rX)
How many passes did you make?
Old Nov 9, 2005 | 05:18 PM
ccfab's Avatar
Default Re: a lil pic of my tig welds, any comments? (k20 jon)
thats one pass.
Old Nov 9, 2005 | 05:21 PM
stirnice's Avatar
The weld is VERY porous. Increase your gas flow, use a bigger cup, and lower the heat. Schedule 10/40 should require 2 passes to get decent penetration. One pass will cause either severe undercutting or poor penetration and both will more than likely result in having to blast the material with heat resulting in poor weld quality.
Old Nov 9, 2005 | 05:22 PM
ccfab's Avatar
Default Re: a lil pic of my tig welds, any comments? (stirnice)
thanks. im using a number 6 cup right now. think 20 lbs is better gas flow wise??
i appreciate the comments, keep em coming
Old Nov 9, 2005 | 05:26 PM
ccfab's Avatar
approx amp suggestion for sched 10?
Old Nov 9, 2005 | 05:33 PM
Dragline's Avatar
I use 18# and a gas lens.
Old Nov 9, 2005 | 07:46 PM
Goal_Kar's Avatar
You can put it to 25-30lbs.
Old Nov 10, 2005 | 10:40 AM
linkmustang's Avatar
kick *** man
Old Nov 10, 2005 | 10:54 AM
hybridmoments's Avatar
Pretty Good............. Pretty... Pretty... Good!!!
Old Nov 10, 2005 | 12:12 PM
project dc2's Avatar
ill giev you 1 tip. clean the metal. jeezuz thats dirty. also a bit hot there buddy. wheres the color ? color is your key to knowing wahts giong on with the metal properties. if its gry you burned off all properties of the metal and thus .. have weakened it
Old Nov 10, 2005 | 12:20 PM
ManBearPig4silly's Avatar
You need to prep the basemetal better and do it in two passes with a lot less heat. If you search enough in this forum you will find a thread by engloid that shows how it's done.
Old Nov 10, 2005 | 02:44 PM
ccfab's Avatar
Default Re: (I4sillypwr)
after 2 pages, all the trwads are tossed,
i didnt see it.
thanks for the tips
sdubfid
Welding / Fabrication
Jan 12, 2008 06:54 PM
allhonda
14
Oct 1, 2006 08:27 PM
redsikiller
Apr 29, 2006 12:04 PM
DamWutaDayM3
Aug 7, 2005 07:33 PM
Cory man
Oct 31, 2004 04:55 PM
