HOW do u read timing on h22a crank pulley?
so there is a dot on the flywheel, and another one?? there are supposed to be 2 right? im bout to get some cam gears and want to be able to set timing right. thanks guys
uh, to get the cam timing right just put the arrows on the cam gears tdc, and the key way on the crank tdc, and check your helms to get the balancer shafts to tdc.
civiccoupe94
Jan 11, 2008 07:08 AM
92 in the works
Feb 23, 2004 07:30 AM
