PLEASE HELP
Old Nov 9, 2005 | 02:07 PM
streetracerof06's Avatar
Default PLEASE HELP
ok so i have just droped my B16a2 into my 92 civic DX, i go to wire it up and the plugs on the engine harness are backwards. i feel so stupid know because i noticed the positive side of the battery on the wrong side and didnt think much of it. what do i do, am i going to have to pull the engine back out to fix this. the engine i pulle out was a SOHC non V-TEC, do i use that harness. Please help me. thanks in advance.
Old Nov 9, 2005 | 02:17 PM
Luserkid's Avatar
Default Re: PLEASE HELP (streetracerof06)
So you put in a RHD drive wiring harness? Take off the harness and use your stock one. You dont need to pull the motor.
Old Nov 9, 2005 | 02:27 PM
Default Re: PLEASE HELP (Luserkid)
so if i put this SOHC non vtec harness on everything is going to work right. and will i have to run V-TEC wires from the ECU. thanks
Old Nov 9, 2005 | 02:28 PM
Luserkid's Avatar
Yea, all youll need to do is wire up VTEC and your set.
Old Nov 9, 2005 | 02:30 PM
to wire up VTEC you run 2 wires to the VTEC solinoid and on as a ground, or is that not right. not sure.
waynesumner
Jun 16, 2013 06:36 PM
Eg_TypeR
Jul 2, 2007 07:13 PM
Mr. Roboto
Dec 10, 2006 06:59 PM
HaNsElBaDaSs
Oct 19, 2006 11:17 AM
B_SERIES_BITCHEZ!
May 21, 2006 08:49 PM
