Intake cam on exhaust side?
Old Nov 9, 2005 | 01:16 PM
DRAGLS's Avatar
Default Intake cam on exhaust side?
Modified by DRAGLS at 7:12 PM 1/5/2007
Old Nov 9, 2005 | 01:32 PM
UncleD's Avatar
Default Re: Intake cam on exhaust side? (DRAGLS)
Old Nov 9, 2005 | 01:43 PM
Rocket's Avatar
It will run but you will most likely break a spring, valve, retainer etc.
Old Nov 9, 2005 | 01:45 PM
projectTeG's Avatar
Default Re: Intake cam on exhaust side? (Rocket)
wow, im subscribing just to see
Old Nov 9, 2005 | 01:50 PM
Rocket's Avatar
The BVTEC swing rocker arm configuration is a variable ratio rocker that requires a asymmetrical lobe (that's whay they are "D" shaped) to induce symmetrical or near symmetrical valve motion. Swaping it around would be like putting the left shoe on the right foot.
Old Nov 9, 2005 | 02:45 PM
Combustion Contraption's Avatar
Good analogy about the shoes.
I think we all understand better now.
Old Nov 9, 2005 | 03:25 PM
jdmsiR20's Avatar
Default Re: (LsVtec92Hatch)
just so you guys know, it is possible on honda motors.
i believe in was a dual cam zc in which it was done by accident.
but yeah, rocket explained it well
Old Nov 9, 2005 | 05:29 PM
drdisco69's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rocket &raquo;</TD></TR><TR><TD CLASS="quote">variable ratio rocker</TD></TR></TABLE>
You wouldn't happen to know the range of ratios, would you?
Old Nov 10, 2005 | 05:51 AM
Rocket's Avatar
Default Re: Intake cam on exhaust side? (drdisco69)
For a BVTEC Mid Rocker the ratio goes from 1.xx to 1.55 for profiles that have a stock base circle and less than 0.493" lift.
Increasing the base circle over stock or having more than 0.493" lift will allow the lobe to contact closer to the pivot point of the rocker. This can get you up to 1.6x rocker ratio when you are near max lift.
Old Nov 10, 2005 | 07:34 AM
drdisco69's Avatar
Excellent, thank you.
Old Nov 14, 2005 | 09:35 PM
Electron_LS-Vtec's Avatar
not to mention the distrubuter would not fit into the intake cam because there isnt a slot for the distrubuter in the end of the intake cam.....
Old Nov 14, 2005 | 09:44 PM
onepoint6i's Avatar
Default Re: (jdmsiR20)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmsiR20 &raquo;</TD></TR><TR><TD CLASS="quote">just so you guys know, it is possible on honda motors.
but yeah, rocket explained it well </TD></TR></TABLE>
accident, how??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Electron_LS-Vtec &raquo;</TD></TR><TR><TD CLASS="quote">not to mention the distrubuter would not fit into the intake cam because there isnt a slot for the distrubuter in the end of the intake cam.....</TD></TR></TABLE>
this is what i was thinking...
Old Nov 14, 2005 | 10:03 PM
drdisco69's Avatar
Default Re: Intake cam on exhaust side? (Electron_LS-Vtec)
You mean exhaust cam.
Old Nov 15, 2005 | 09:29 AM
hybrid_vtec's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rocket &raquo;</TD></TR><TR><TD CLASS="quote">The BVTEC swing rocker arm configuration is a variable ratio rocker that requires a asymmetrical lobe (that's whay they are "D" shaped) to induce symmetrical or near symmetrical valve motion. Swaping it around would be like putting the left shoe on the right foot.</TD></TR></TABLE>
But what about the nonvtec engines, as their rocker ratios are 1.75:1 on both intake and exhaust?
Im not asking about switching them, but more or less what if you were to use 2 intake cams in the head.
Old Nov 15, 2005 | 09:43 AM
Kendall's Avatar
I've done it before on a B16 using Crower springs/retainers. I put a Skunk2 Stage 1 intake cam in the intake side and the stock intake cam in the exhaust side. I had to use adjustable cam gears and place the "exhaust" cam several teeth (can't remember how many) off in order for it to work. It ran pretty damn good with no issues, but was only assembled as such for two weeks before I sold the S2S1 intake cam and replaced both with CTR cams so I can't comment on long term reliability.
LoW ToNE
Sep 14, 2007 09:55 AM
hondapwr
16
Aug 5, 2005 08:51 AM
EGinNY
13
Feb 20, 2004 10:34 AM
xsiv
Jan 11, 2004 06:15 PM
streetrage
Oct 15, 2003 06:04 PM
