Is a Mugen header good for the Toda B's or is the Hytech / SMSP / Spoon better ?
Old Mar 10, 2002 | 09:28 AM
SpoonFed's Avatar
Default Is a Mugen header good for the Toda B's or is the Hytech / SMSP / Spoon /Toda better ?
Which one is the better header for the Toda B's...Did the "great header test" but the test was only done on stk itr cams...What u think..can't loose on Mugen right..
thanks
[Modified by spoonfed, 6:35 PM 3/10/2002]
Old Mar 10, 2002 | 09:32 AM
TypeR0149's Avatar
Default Re: Is a Mugen header good for the Toda B's or is the Hytech / SMSP / Spoon better ? (spoonfed)
out of all the headers you listed the Mugen is by far the most least used, and archaiac design.
I think Mugen is good quality, but you can get alot more power from a SMS, for less money
Old Mar 10, 2002 | 09:45 AM
Racer-X's Avatar
Default Re: Is a Mugen header good for the Toda B's or is the Hytech / SMSP / Spoon better ? (Vegeta)
Has anyone ever dynoed a Mugen 4-2-1? I've seen 4-1 dynos but it's not right to compare 4-1 to 4-2-1's as they both got there advantages and dis advantages.
I myself like Toda and Spoon headers but SMSP header runs neck to neck with the Toda from what I saw in dyno charts. I figure the Mugen 4-2-1 would be somewhere close but under the spoon header performance wise due to the older design. The hytech is top performer from what I seen in the dyno testing done overlast yr but it's not much better I believe it was 3-4whp in topend over the SMSP and Toda headers but I know simple heat coating of the Toda header can give you those extra hp back and close up the gap on the top end.
I guess it will depend on what you plan to use the car for? drag or road race or just everyday driving?
Old Mar 10, 2002 | 09:49 AM
Pinhead's Avatar
New User
Default Re: Is a Mugen header good for the Toda B's or is the Hytech / SMSP / Spoon better ? (Racer-X)
I always thought smsp outperformed Toda...can anyone confirm this?
Old Mar 10, 2002 | 10:12 AM
Racer-X's Avatar
Default Re: Is a Mugen header good for the Toda B's or is the Hytech / SMSP / Spoon better ? (Pinhead)
Well I forgot who had all the dyno plots online but I know it was tied or close to within 1-2whp of each other. Though I could gotten it backwards but I know it basically tied one of the independent header makes from the US.
But I know there around on someones website I can't find them as I apparently deleted my link to it.
Old Mar 10, 2002 | 10:25 AM
Racer-X's Avatar
Found it I thought it was SMSP and Toda both got 190whp on top end according to the dyno testing they did back then.
Here was the last one they did that compared the two.
Old Mar 10, 2002 | 10:29 AM
Pinhead's Avatar
New User
Cool nice graph plot....anyone know where they sell Toda Headers and how much they are?
Old Mar 10, 2002 | 10:30 AM
SleepyR's Avatar
New User
I asked this way back, but know one replied, but who has the air/fuel ratios for the great header test, and also I want to know the order that each of the headers were tested? Can someone help me out....
Old Mar 10, 2002 | 10:52 AM
Racer-X's Avatar
Default Re: Is a Mugen header good for the Toda B's or is the Hytech / SMSP / Spoon better ? (SleepyR)
I would posted this up back then if I saw your post. I believe the folks that did the testing should be able to tell you all the finer detials of the test.
Old Mar 10, 2002 | 12:47 PM
SMSP's Avatar
Default Re: Is a Mugen header good for the Toda B's or is the Hytech / SMSP / Spoon /Toda better ? (spoonfed
If you are leaning towards the Mugen, you should really think about the stainless DC JDM. The Mugen has 45mm or 1.77" primaries (like almost every JDM header except the ITR) and DC has 1.75". There primary lengths are very close but I feel the collector is actually better in the DC than the Mugen. Ground clearance between the 2 are probably very similar since the tube layouts are almost identical. BTW, all the JDM 4-2-1 headers use 45mm primaries and 50mm secondaries.
Old Mar 10, 2002 | 01:10 PM
Blade's Avatar
New User
They're around $975 or so I beleive. www.todaracing.com/dealer.html
Old Mar 10, 2002 | 02:27 PM
mafay2's Avatar
New User
Default Re: Is a Mugen header good for the Toda B's or is the Hytech / SMSP / Spoon better ? (Blade)
One big advantage of the Toda is the ground clearence. I am not sure you can use the header results to decide which header is best for Toda B's, because the tests were done on a relatively stock car. But I guess you can't go wrong with Toda header with Toda cams.
Old Mar 10, 2002 | 03:32 PM
AJ PwR's Avatar
Toda and SMSP showna very aggressive top end power. If you want more top end power then consider the above.
Spoon has the most torque at the mid-range which means more useful power for daily driver or Auto-xers.
Since nobody have made a header test with Toda Bs with tuning so it is very hard to say cuz those plots are dynoed from a stock B18C Motor.
Different I/E combo sure will effect the results . I have been installing a lot of Toda B cams with Spoon / Mugen421 / T.1 header with tuning you will see about 185-190 ranges.
The figures are based on:
-B18C5 motor
-Toda B / Spoon camgears
-stock valvetrain / injectors
-Spoon filter
-header (either one above)
-stock b-pipe
-Spoon N1 muffler
-test pipe
-VAFC
[Modified by AJ PwR, 4:34 PM 3/10/2002]
4doorH22
Honda S2000
14
Sep 26, 2009 04:49 PM
TypeR01-424
Jun 19, 2002 11:06 AM
GettaluvR
May 5, 2002 05:03 PM
White Dragon
Nov 4, 2001 06:37 PM
APEX i GSR
Jul 31, 2001 08:43 PM
