89' CRX Low Idle, Chk Engine Light On, 12 flashes on ECU?
Old Nov 9, 2005 | 08:46 AM
aviationstation's Avatar
Default 89' CRX Low Idle, Chk Engine Light On, 12 flashes on ECU?
All, I just picked up my second CRX, an 89 1500 (stock) 5 speed. Runs find but idles low & the CEL is now on. Pulled the pax cover plate & with the key on, the ECU flashes 12 times in a row & repeats. It is not displaying 1 flash, then a pause, then two flashes, but 12 consecutive flashes. Any ideas?
I didn't jump any plugs, leads or wires. As I recall, retrieving codes is simply a matter of access the ECU LED, then turning the ignition key to on & counting the flashes.
Thanks!
M Randolph
Old Nov 9, 2005 | 09:13 AM
Frankei's Avatar
Default Re: 89' CRX Low Idle, Chk Engine Light On, 12 flashes on ECU? (aviationstation)
List of ECU error codes
http://ccnz.nvrfgt.co.nz/faq/ecuerrorcodes.htm
Old Nov 9, 2005 | 10:40 AM
Default Re: 89' CRX Low Idle, Chk Engine Light On, 12 flashes on ECU? (Frankei)
So is it accurate to assume that the 12 consecutive flashes represent a code of 12, or is 12 typically indicated by one flash, a delay, then two flashes?
I'm going to assume that the 12 in-a-row flashes are for TC 12, which is EGR related.
Thanks!
Old Nov 9, 2005 | 10:59 AM
vtecn8ive's Avatar
12 flashes equals code 12.
Not sure how to troubleshoot this one sorry.
Old Nov 10, 2005 | 08:47 AM
Default Re: 89' CRX Low Idle, Chk Engine Light On, 12 flashes on ECU? (vtecn8ive)
vtecn8ive,
Thanks for the reply. Off to find an EGR assy.
mBr
jakop92
18
Oct 26, 2009 05:28 PM
712Da9
Oct 13, 2009 05:03 PM
. M i c h a e l
May 24, 2006 05:32 AM
. M i c h a e l
Feb 14, 2006 04:52 AM
ZColeon
Nov 12, 2001 07:21 PM
