mini me swap question please help come onnnnnn
hi you doing guys
well this is what happen im doing a mini me swap on a 1990 civic but its not with 4 injectors is that single injector how the hell do i wire all the new injectors and the distributor and a hole mess of sensors
by the way im using a p28 obd 1
and i have a obd0 civic hatchback 1990 dx single injector
how the hell do i make it 4 injector and how will i wire it please help me thanks
.............<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by delcivic »</TD></TR><TR><TD CLASS="quote">hi you doing guys
how the hell do i make it 4 injector and how will i wire it please help me thanks</TD></TR></TABLE>
I dont understand your question?..
Is your car carborated?
you need to do the mpfi swap. Plenty of info is out there as it is a common swap. Go to search and just type mpfi swap im sure youll find plenty of info. My freind did that swap and he found all his info on ht
haha...go to the homepage..look to the top right-hand side..it says search. once your in there its pretty straight forward..make sure you check the archived content bubble.
heres what i got from the first post:
1. you have a dpfi motor
2. youre doing a minime swap
3. youre car is currently OBD-0
4. you want to run a p28
well if i am correct on the above, youll first have to get a complete vtec head and put it on... next youll need to rewire to make your car OBD-I... then youll have to wire in vtec and then wire in each individual injector... i did this same exact swap except i just swapped in a z6... i used a rywire harness and it saved me a ton of headaches... my advice would be to go to rywire.com and by their dx- d16z6 harness... its relatively inexpensive, great quality, and its a hell of a lot easier to do the swap... oh and btw your current motor has two injectors in the throttle body... thats why its called Dual Point Fuel Injection(dpfi)
... good luck with it
-Josh
-Josh
jadugartir
Feb 23, 2005 03:05 PM
