engine noise,,,help??!!
Old Nov 8, 2005 | 06:49 PM
liem43's Avatar
Default engine noise,,,help??!!
my car makes a loud knocking when im warming up my engine..but later when its warmed up already and ready to go..the sound goes away...someone told me i had to adjust my valves...but is that right????i change my oil constantly and the oil is at the right level....
Old Nov 8, 2005 | 07:21 PM
The_Todd's Avatar
Farts in the shower
Default Re: engine noise,,,help??!! (liem43)
A valve adjustment would probably help out but honda valves are notorious for being loud at cold start up.
Old Nov 8, 2005 | 08:15 PM
iam7head's Avatar
Default Re: engine noise,,,help??!! (.ken)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .ken &raquo;</TD></TR><TR><TD CLASS="quote">A valve adjustment would probably help out but honda valves are notorious for being loud at cold start up. </TD></TR></TABLE>
and accord f series are dubbed "sewing machine"
the mechanical valve are known for being noisy, get a valve ajustment if you haven't already got it.
if you have a 5th gen v6, the hydralic valves are known for ticking when warming up under light load
Old Nov 8, 2005 | 08:27 PM
P_Adams's Avatar
Is it a Loud, deep knock? Or a higher pitched "Ticking" noise?
P
Old Nov 9, 2005 | 12:42 AM
liem43's Avatar
Default Re: engine noise,,,help??!! (P_Adams)
the noise is not too loud but not too low right in the middle. it sounds like its hollow inside or something.. i guess you can call it a clicking noise but it goes away.
Old Nov 9, 2005 | 12:43 AM
liem43's Avatar
i dunooo what generation my accord is,, i just need some advice with my 98 accord coupe 4cy. sohc
Old Nov 9, 2005 | 12:45 AM
The_Todd's Avatar
Farts in the shower
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by liem43 &raquo;</TD></TR><TR><TD CLASS="quote">the noise is not too loud but not too low right in the middle. it sounds like its hollow inside or something.. i guess you can call it a clicking noise but it goes away. </TD></TR></TABLE>
Sounds like valves to me, I would do a valve adjustment but like I and others have said the f-series motors are notorious for being loud.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by liem43 &raquo;</TD></TR><TR><TD CLASS="quote">i dunooo what generation my accord is,, i just need some advice with my 98 accord coupe 4cy. sohc </TD></TR></TABLE>
6th generation.
Old Nov 9, 2005 | 02:55 AM
HondaMike17's Avatar
it kinda makes sense doesnt it? of course your car is going to be louder when you start it, from a cold start my honda 5th gen is very loud, just like all of them just about, i can hear my car warming up all the way across my yard loudly, thats what it does, when it warms up it purrs like a kitten , sounds perfectly normal to me, but if you want to be safe go get an adjustment
Old Nov 9, 2005 | 04:26 AM
deserthonda's Avatar
as eeryone says most likely it is the valve lash a bit loose but i have seen the same kind of noise pattern with Piston pin slap,,
Old Nov 9, 2005 | 04:30 AM
THEROPE's Avatar
Default Re: engine noise,,,help??!! (deserthonda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by deserthonda &raquo;</TD></TR><TR><TD CLASS="quote">as eeryone says most likely it is the valve lash a bit loose but i have seen the same kind of noise pattern with Piston pin slap,,</TD></TR></TABLE>
you beat me to it
i was going to say piston slap if it sounds hollow
Old Jun 30, 2010 | 08:41 AM
sqeeek's Avatar
I want to get my valves adjusted,
but I just spent all my money making the dang thing pass inspection. (320k miles, totaled twice, different engine than original)
How hard is a valve adjustment? I mean, I do 90% of my own repairs, but...
My problem is, I'm a 17 year old kid with nothing but Google for info on how to fix stuff, and the only thing I get out of Google on valve adjusting is 'you should go get a valve adjustment'
Anyone know how to adjust the valves, or where to find out how? I assume you take the valve cover off, line the crank up so the valves are closed and turn the nut until it's tight enough, but... that's all I've got.
And sorry for bumping ancient history, btw.
GSRBrent
Dec 2, 2007 09:25 PM
cleartouch33
Dec 15, 2006 09:18 AM
ej2civic
Oct 2, 2005 09:43 AM
Bewkrazed
Mar 4, 2005 08:20 AM
