Buzzing Sound in 4th & 5th gear?
Old Mar 10, 2002 | 04:29 AM
vtir's Avatar
Default Buzzing Sound in 4th & 5th gear?
When driving normally, 1st, 2nd and 3rd gears sound fine. When I get to 4th or 5th, there will make a low buzzing sound when gear is engaged. Happens when foot is on and off the accelerator. In neutral, revving engine will not reproduce sound. Any idea what is going on? TIA.
Old Mar 10, 2002 | 04:07 PM
vtir's Avatar
Default Re: Buzzing Sound in 4th & 5th gear? (vtir)
TTT
Old Mar 10, 2002 | 05:00 PM
VTi NA's Avatar
I get this too on the freeway at around 4K, but the buzzing is usually coming from the hatch area (the exhaust resonates a bit too much I suspect). Can you tell where exactly the buzzing is coming from?
Old Mar 10, 2002 | 05:19 PM
vtir's Avatar
Default Re: Buzzing Sound in 4th & 5th gear? (STi -RA)
It comes from the engine bay area.
Old Mar 10, 2002 | 05:40 PM
redteg1's Avatar
dynamat it! ...oh yea and the "buzz" u get at around 4k might be something called vtec if u have a gsr.
Old Mar 10, 2002 | 05:46 PM
vtir's Avatar
Default Re: Buzzing Sound in 4th & 5th gear? (redteg1)
It isn't VTEC engaging. That is way louder compared to what I am referring to.
This is like a Zzzz sound when at 2-3k but only in 4th and 5th gear. You can hear it when accelerating and when you take your foot off the throttle. Is it the tranny or the exhaust? If it's the exhaust, why do I not hear it in 1st 2nd and 3rd gears? Low tranny oil?
Old Mar 10, 2002 | 07:28 PM
ebelp's Avatar
Could it be your heat shield rattling?
Old Mar 10, 2002 | 07:52 PM
George's Avatar
Was about to ask the same question. Just had clutch job done and now when I engage in gear, I get this low buzzing sound. Not real loud, but you can hear it. When not in gear, you don't hear it. 92 Integra LS
Old Mar 11, 2002 | 12:26 AM
vtir's Avatar
Default Re: Buzzing Sound in 4th & 5th gear? (George)
Checked. It is not the heat shield on the header or the cat.
Low tranny fluid be the cause?
Recaan
Aug 8, 2016 08:33 AM
Recaan
Transmission & Drivetrain
Aug 7, 2016 12:24 AM
rubocop
Apr 13, 2015 10:03 PM
KidKavika
Mar 31, 2013 12:25 PM
b17gsr
Nov 4, 2003 08:41 AM
