Electric problem
Old Nov 8, 2005 | 05:02 PM
samurablaze's Avatar
Default Electric problem
My 91 hatch would have zero power after not bein used for a day or 2. Installed new alternator. The next day the speedometer didnt work and the check engine light went on. After giving the car a jump it dies within a minute of taking off the jumper cables. Anyone know wuts up? The alternator is installed correctly. Thanks
Old Nov 8, 2005 | 06:28 PM
31flavorscivic's Avatar
Default Re: Electric problem (samurablaze)
You may have a bad battery. I know that one time I had an alternator that blew a battery; it would not hold a charge at ALL. It sounds like that's whats happening to you. I suggest getting a new battery
The speedometer is driven by a cable, so I am assuming that it either fell out or broke.
As for the check engine, do you know what code the ECU threw?
Old Nov 8, 2005 | 06:31 PM
Role Model's Avatar
Default Re: Electric problem (31flavorscivic)
use a multimeter on your fuse box (remove fuse by fuse and check where there's a resistance then when you'll find it you'll know whats the problem)
alperx
Nov 27, 2012 05:47 AM
davids8126
Nov 26, 2009 10:06 PM
biggjerryc
Oct 23, 2008 08:45 PM
b16a1eg6
Jan 19, 2007 03:10 PM
