Built ls-vtec 85mm, what cams to use?
Old Nov 8, 2005 | 04:42 PM
BobbyStylz's Avatar
Default Built ls-vtec 85mm, what cams to use?
A friend of mine has an ls-vtec set-up with about 12.0:1 compression. He is running a sleeved ls block with a 85mm bore. For now he has a stock port b16 head with portflow valvetrane. I dont have much more info on it right now .. but any help would be apreciated. I did a little searching but i didnt find much about any one with 85mm set-up, HELP please looking to buy some tonight
Old Nov 8, 2005 | 05:06 PM
ebpEM1_DJ's Avatar
Default Re: Built ls-vtec 85mm, what cams to use? (BobbyStylz)
BUMP
Old Nov 8, 2005 | 05:21 PM
highendmotorsports's Avatar
Default Re: Built ls-vtec 85mm, what cams to use? (ebpEM1_DJ)
look into some BLOX type B's. Highend autosports
Mike
Old Nov 8, 2005 | 05:27 PM
PURPLETERROR aka BIGMATT's Avatar
skunk pro2's or rocket m24's
Old Nov 8, 2005 | 05:28 PM
rainforest's Avatar
Default Re: Built ls-vtec 85mm, what cams to use? (highendmotorsports)
look into recent dynos skunk 2 pro 1's have been getting lots of positve feed back, look into rocket motorsports camshafts
or buddy club IV's
search on all the dynos and feel them out for yourself
Old Nov 8, 2005 | 05:30 PM
NA.GEORGE's Avatar
m22xx or bc5 or skunk pro series 3 all really aggresive cams but the head ported and the motor tuned
Old Nov 8, 2005 | 11:56 PM
UncleD's Avatar
Default Re: Built ls-vtec 85mm, what cams to use? (NA.GEORGE)
I personally would do the M22xx with that motor. With a stock head I think the M24's would be a bit much. What header/exhaust and engine management is he running?
Old Nov 9, 2005 | 03:54 AM
BobbyStylz's Avatar
Default Re: Built ls-vtec 85mm, what cams to use? (clean rice)
jdm type r header, with greddy evo catback, carsound 2.5 cat, he is goin to upgrade to kteller 2.5 with mostlikely an es oval no cat
Old Nov 9, 2005 | 03:56 AM
BobbyStylz's Avatar
sorry .. right now .. shitty *** tune with crome .. hes looking to get better cams b4 he gets it tuned and then get a ported head in the near future
Old Nov 9, 2005 | 04:56 AM
Aquafina's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by clean rice &raquo;</TD></TR><TR><TD CLASS="quote">I personally would do the M22xx with that motor. With a stock head I think the M24's would be a bit much. What header/exhaust and engine management is he running?</TD></TR></TABLE>
He'd still make power with the M24's, and if headwork IS in his plans, then they would be the cam to go with.
If he does not plan on doing headwork, then M22's would be the cam to get.
Old Nov 9, 2005 | 09:37 AM
Tbone's Avatar
Default Re: Built ls-vtec 85mm, what cams to use? (rainforest)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rainforest &raquo;</TD></TR><TR><TD CLASS="quote">look into recent dynos skunk 2 pro 1's have been getting lots of positve feed back, look into rocket motorsports camshafts
or buddy club IV's
What he said^^^^^^^^^^^^^^^^^^
I say the pro 3 , buddy 5 are too big and not needed.. They were too big for my motor and mine is 12.5 cr
Old Nov 21, 2005 | 05:24 AM
NJcoupe's Avatar
get the m24x's or the skunk2pro2's.
Old Nov 24, 2005 | 05:28 PM
sacjdmz's Avatar
GO WITH TODA SPEC B. THATS THE BEST CAM OUT OF ALL GOOD TOP-END, MID-RANGE, AND LOW-END AT ALL RPMS!!!!!
Old Nov 25, 2005 | 04:40 AM
jt-sport's Avatar
bobby, do you run stock rods?? im building in progress 85mm stock slevees, and going to skunk2 pro 2
turbob18si
50
Aug 22, 2014 07:50 AM
blue_EM1
Aug 12, 2008 03:14 PM
XkjeldorX
Aug 2, 2008 03:09 PM
fakieSI
29
Feb 7, 2008 12:44 AM
IGotVTECyo
11
Sep 30, 2007 07:59 AM
