pulled out yellow harness behind dash and now car wont start..solid cel?help??
Old Nov 8, 2005 | 01:26 PM
neEven's Avatar
Default pulled out yellow harness behind dash and now car wont start..solid cel?help??
i was in the process of swapin over a gsr dash into my 2nd eg and this time decided to take all the yellow wrapped wiring harnesses off to clean **** up since i do not have airbags anymore
before i did this i swaped wires from the eg to the teg gauge cluster..started it and cel lit up and went away as normal and all gauges and lights worked perfect
then i turn off car and rip out all the yellow wrapped wires and plugs that is for the airbag and now solid cel and car wont start
car turns over and over just wont start like when my ignitor went out a while back
i put it all back in and still solid cel jumped and not jumped and car wont start
ecu looks straight but dont really have access to one where im at
ive also taken the ecu fuse out for a half hour to reset
i searched and found this post sayin these wires are straight to pull out so im confused i donno what to check here
https://honda-tech.com/zerothread?id=1285065
any ideas??
thanks for helpin
Old Nov 8, 2005 | 01:34 PM
JDMlyfestyle's Avatar
you might have pulled a lil too hard and messed up some other wires.
Old Nov 8, 2005 | 04:04 PM
neEven's Avatar
Default Re: pulled out yellow harness behind dash and now car wont start..solid cel?help?? (neEven)
up
Old Nov 8, 2005 | 04:12 PM
marshun's Avatar
reset air bag ecu
Old Nov 8, 2005 | 04:18 PM
ekcivic9's Avatar
the SRS system has an airbag ecu? what?!
Old Nov 8, 2005 | 04:23 PM
neEven's Avatar
yea i donno what happend here cause i dont think i coulda blown anything in the dizzy like the ignitor without even driving the car...i didnt move or touch any grounds under the hood
are there any behind the dash i might be overlooking??
i remmeber thinkin i heard a fuse pop but i didnt find any blown
Old Nov 9, 2005 | 10:56 AM
neEven's Avatar
now i find out that there are 2 wires in there (yellow air bag wires all wrapped up together)that hook up to the ignitioin switch
so im checkin that out and the white is constant power and the 3 others (blk w/ ylw, ylw, wht w/ blk) are all powerd up with key turned to II seems straight
i dont hear the fuel pump turnin on so i swap out main relay and nothin changes
im convinced i need a new dizzy to try next but cant come by one easily unless anyone readin this is in tallahassee ???
what coulda blown cuttin these wires to the ign switch if no fuses blew and the main relay is straight??
also wouldnt a blown ignitor or coil(dont think its the coil though) throw a diff code then a solid cel??
thanks for the help for real anyone reading
thanks for readin and always open to ideas these are the type of mistakes that really **** me off till im done and fixed it
nwgsrgiggen
May 14, 2010 12:22 PM
tmrtwo
Jun 19, 2009 02:51 PM
2.2 teg
May 29, 2007 04:54 PM
civic95hbvtec
28
Mar 18, 2007 01:34 PM
Pandahatch
Feb 5, 2004 06:16 PM
