what do i need for hondata s200 or s100
hi all
i got a b18b1 integra 2000 mostly stock under the hood. I want to got turbo as winter project, im a little lost with the electronic though. ive seen what hondata s200 can do and it seem t be a very good unit. But i got no clue what i need to do with my ecu to hook it up.
Or should i buy an other Ecu!? or should i keep mine and put an s100 in there...
Need help
Thx a lot.
I searched by da way, maybe im blind but hey...
Need help
Thx a lot.
you will need a OBD1 ecu and a jumper harness..then the ecu will need to be chipped for hondata..then you just plug and tune and your ready to go..
nope..you can use any of those..I have been finding P72 obd1 ecus cheap on ebay lately so I would just look for any of those part numbers and buy the best priced one you find..
with hondata you can disable vtec so they will work no problem.
Why get an s200 when you can get an s300? That way, you won't have any boxes and wires everywhere.....i say look into the s300 - it has every option the s200 can have plus more....all in one little unit inside the ecm.
