Measurements: Type-S Piston
I've searched and couldn't find the exact measurements for the Type-S Pistons (oversize).
Does anyone know what the exact finished cylinder bore size (for oversize) along with the
ring groove widths and depths measurements?
I ask because I'm trying to purchase new piston rings made by TotalSeal. Has anyone ever used their products in their H22's?
-Thanks in advance
-Thanks in advance
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98silverlude »</TD></TR><TR><TD CLASS="quote">whats up with the a and b pistons? i keep seein that but i don't kno what the difference is for</TD></TR></TABLE>
The diff. is for the variation in the frm diameter. Honda is a stickler for tolerances.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98silverlude »</TD></TR><TR><TD CLASS="quote">also can you run all a's or all b's?</TD></TR></TABLE>
depends on what is stamped on your motor.
You can run all A's (with a little honing of a B hole if needed), you can run all B's if you have all B holes, but not if you have mixed holes eg ABAB, AABB etc. For mixed holes you need the right sizes or you can run all A's.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by khalal538 »</TD></TR><TR><TD CLASS="quote">Ok, how about the ring groove widths and depths?</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98silverlude »</TD></TR><TR><TD CLASS="quote">and wheres the stamping at?</TD></TR></TABLE>
like on top of the water pump
measurements?
measurements?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thedread »</TD></TR><TR><TD CLASS="quote">
The diff. is for the variation in the frm diameter. Honda is a stickler for tolerances.</TD></TR></TABLE>
they have to be with the FRM sleeves.
marvinmark21
Jan 14, 2008 09:36 AM
