window not goin up
Old Nov 8, 2005 | 07:52 AM
1sikhatch's Avatar
Default window not goin up
i am having trouble with my pass. power window, it goes down but not up. I tried my switch in another civic and it worked so i know its not the switch. the only way for me to get the window up is to run direct current to it with 2 wires. whatcould be the problem?
Old Nov 9, 2005 | 02:00 AM
1sikhatch's Avatar
Default Re: window not goin up (1sikhatch)
fyhjfghf
Old Nov 9, 2005 | 04:53 AM
Phantastic's Avatar
did you check if the window went off the track? my old car had the same problem.
Old Nov 9, 2005 | 01:35 PM
1sikhatch's Avatar
Default Re: window not goin up (Phantastic)
yes its still on the track
Old Nov 9, 2005 | 01:41 PM
green-'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1sikhatch &raquo;</TD></TR><TR><TD CLASS="quote">i am having trouble with my pass. power window, it goes down but not up. I tried my switch in another civic and it worked so i know its not the switch. the only way for me to get the window up is to run direct current to it with 2 wires. whatcould be the problem?</TD></TR></TABLE>
After you ran direct current to roll it back up, did you use the switch to roll it down again?
Old Nov 10, 2005 | 02:42 AM
1sikhatch's Avatar
Default Re: window not goin up (green00EX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by green00EX &raquo;</TD></TR><TR><TD CLASS="quote">
After you ran direct current to roll it back up, did you use the switch to roll it down again?</TD></TR></TABLE>
yea, and the driver switches doesn't turn it down
91integraLSVTEC
May 10, 2005 01:15 PM
4bangin
Oct 4, 2004 03:44 AM
spd18
Nov 9, 2003 01:57 PM
TheIntegraGuy
May 15, 2003 06:18 AM
