Help with Axle replacement
Old Nov 7, 2005 | 10:37 PM
J.Nguyen2's Avatar
Default Help with LCA & strut
so the otherday i swereved to avoid a guy but hit the crub instead. I hit it at like maybe a 45 angle. My rim (steelie) is bent, and the tire isn't in the center of the wheel housing, it's more towards the back. I'm told i have a bent axle, I hear knocking/ticking/brushing sounds while slowing down. My alignment is fucked and the car vibrates along with the steering wheel when i drive.
My question is how much do you think it'll cost to fix it all? I drive a 2000 ex
Anyone have DIY tips? diagrams would really be helpful.
Modified by littleblackcoupe at 11:16 PM 11/11/2005
Old Nov 7, 2005 | 10:38 PM
J.Nguyen2's Avatar
Default Re: Help with Axle replacement (littleblackcoupe)
oh yeah it was the front right tire that curbed.
Old Nov 7, 2005 | 10:47 PM
life sux die's Avatar
RIP 1032
https://honda-tech.com/zerothread?id=382416
Old Nov 7, 2005 | 10:48 PM
ek99's Avatar
Most likely you bent your lower A arm. Your bearing could also be messed up and so could the upper a arm. The only way to tell is to take it appart and visually inspect it. I'd say about $300.
Old Nov 8, 2005 | 12:14 AM
Astig's Avatar
Default Re: Help with Axle replacement (ek99)
Yeah, it DEFINATELY is not just an axle.
Old Nov 9, 2005 | 04:16 PM
J.Nguyen2's Avatar
Default Re: Help with Axle replacement (Astig)
The wheel wobbles when i drive would that stop if i got a new wheel? Mechanic says its the lower control arm, strut fork.
is that a DIY job? what's the level of difficulty? can it be done in one afternoon?
Old Nov 9, 2005 | 07:01 PM
peacexisxfree's Avatar
sounds like more than just your wheel. im sure youd still have major alignment problems, even if you got a new wheel. that is totally a diy job, but if you havent done it before, allow yourself the whole day to do it.
everything is pretty self explanatory down there...and im sure there are plenty of write ups on h-t alone to get you through it
Old Nov 10, 2005 | 11:06 PM
J.Nguyen2's Avatar
Default Re: Help with Axle replacement (peacexisxfree)
thanks for the bit of encouragement. I really need it. mechanic said it'll cost 776 to fix it! phssst. I estimate i can do it for about 200 maybe less
Old Nov 10, 2005 | 11:09 PM
J.Nguyen2's Avatar
also would getting a new wheel help with the bumps? it feels like im rolling over a bump everytime i accelerate, I know it wont fix the alignment and steering wheel shake, but would you think it would help the bumps?
also what are the adverse effects of driving my car in this condition, other than tire wear?
could my sway bar be bent too? if so shoould i just swap both LCA's for the Si's so i can put a bigger sway bar in?
haha sorry for all the questions.
Old Nov 11, 2005 | 11:15 AM
J.Nguyen2's Avatar
bump.
Old Nov 11, 2005 | 11:22 AM
xbwa's Avatar
bump bump bump it up
Old Nov 12, 2005 | 09:41 PM
J.Nguyen2's Avatar
is a strut fork the same thing as a damper fork?
Old Nov 13, 2005 | 12:26 PM
Supa_Slow_Civic's Avatar
Default Re: (littleblackcoupe)
You need to get under the car and look at the damage from the bottom side. Bc I'm sure there more damage then what the mechanic said. I bet you bent the lower subframe. I did the same thing to my civic and my subframe was screwed. So you might wanna check it out
mimog3
Sep 18, 2012 03:44 PM
Mendes
Feb 21, 2008 01:46 PM
ryanstev
Suspension & Brakes
Nov 13, 2007 05:24 AM
Slammed1993
Oct 16, 2006 08:19 PM
Jizzmaster Zero
12
Jun 16, 2006 02:42 PM
