Parked my car for 5 months, now it surges at idle.
Old Nov 7, 2005 | 07:48 PM
ccjustin's Avatar
Default Parked my car for 5 months, now it surges at idle.
I haven't touched the motor, it's a stock 1997 d16y7. It idles fine for a couple minutes then drops, then races and so on. When I drive it doesn't hesitate or surge when in gear. I tried dry gas, then I drove around until the tank was empty, then filled it with 93. I checked all vaccum lines for cracks or leaking, No check engine light. I pulled off the TB and unbolted the IACV from it and cleaned it out, it was siezed in place, (3-wire rotary style) I got it moving again, but the idle still surges. Thanks for the help.
Old Nov 7, 2005 | 07:52 PM
civic_driver's Avatar
check your coolant...make sure there's no air... and any crackings from dried out hoses (vacuum leaks).... does your car have a FITV? if it does then that's the most likely problem.. if not then you probably need a new EACV or there's a bad connection in the EACV line
i would reset the ECU by pulling the fuse just to make sure it updates for current conditions
Old Nov 9, 2005 | 06:29 AM
ccjustin's Avatar
Default Re: Parked my car for 5 months, now it surges at idle. (ccjustin)
Fixed it! Thought I'd post the solution as well as the problem. It was the IACV after all, I double checked against another d16y7. The good one moves very smoothy and mine felt like there was sand in the "bearing?" anyway it turned back and forth with a lot of resistance. I sprayed it out with carb cleaner and brushed the crap out of it, it's not perfect, but it moves a lot better, and the car idles fine.
BOOSTED_JDM_DB8
Feb 3, 2006 01:01 AM
sleepyeg6
Aug 27, 2005 02:29 PM
Boofster
May 22, 2005 10:59 AM
prelude00sh
Apr 7, 2005 02:08 PM
mrnicolas
Oct 31, 2002 02:13 AM
