91 civic si
Old Nov 7, 2005 | 06:39 PM
JDMbitches's Avatar
Default 91 civic si
i am planin to buy a 91 civic si and turbo it but its got 157k miles who i do any damage to the motor if i had it a like 6 to 8 psi on the stock motor?
Old Nov 7, 2005 | 07:09 PM
Pantysniffer's Avatar
Default Re: 91 civic si (JDMbitches)
it depends. 5-6 psi is usually safe. but its best to rebuild it first though.
Old Nov 7, 2005 | 07:56 PM
JDMbitches's Avatar
Default Re: 91 civic si (Pantysniffer)
well if i put it at 5-6 psi and had a good tune what numbers would i be thrown down
Old Nov 7, 2005 | 08:25 PM
JDMbitches's Avatar
the motor is a d16a6
Old Nov 7, 2005 | 08:29 PM
Stunna MIKE's Avatar
yes i am curious also.. i want to turbo my d16a6.. probly gonna pay $600 for everything..
FREE BUMB
Old Nov 7, 2005 | 08:36 PM
user 98292739's Avatar
if you have not bought the car yet i would go and do a compression check to see if if it throws up good numbers or at least consistent. if you have good consistent numbers then start to turbo. a good rule of thumb is for every PSI you gain about 10 psi and 13 on a good tune. but this is all bullshit because it all depends on everything you have. from the pipes to the turbo to the tune to the injectors to ic everything has some effect. so id say if you had a great tune and correct equipment an a6 should yield you 16xish hp but if you have a good motor it should handle 9-10 psi fine but thats the max which would put you over 200 hp.
Old Nov 7, 2005 | 08:44 PM
Default Re: (Rexified)
but thats on a t25 turbo right ??
Old Nov 7, 2005 | 08:45 PM
# T-25 DSM 2g Turbocharger
# Oil Feed Line DSM
# STD Manifold DSM 1g Blow off Valve
# Starion/Conquest Intercooler
# DSM 380cc Injectors B&M Command Flow
# MSD 6BTM w/Cap & Coil
# Autometer Pod Oil & Boost Gauge
# Adapter Plate
# Downpipe
# Downpipe Adapter Plate
# Charge Pipes
# Misc Gaskets
hmongyaj87
Aug 25, 2007 04:12 PM
91(si)hatchey
Nov 7, 2006 08:15 AM
CR-Xtom
Mar 16, 2005 05:39 AM
RJH6
Nov 1, 2004 08:49 AM
turbolude92
Sep 25, 2003 08:07 PM
