SOHC VTEC Solenoid 92-95 Civic D16Z6 D16Y8 D15B
Old Nov 7, 2005 | 06:10 PM
Exempt's Avatar
Default SOHC VTEC Solenoid 92-95 Civic D16Z6 D16Y8 D15B
VTEC solenoid removed from a JDM D15B VTEC... It does not have a VTEC oil pressure switch (some JDM engines dont) so it is good if u want to run the P08 ECU with your D15B swap... It will also work on a P28 ECU if you wire it up correctly... Also, It does have a bolt in place of the VTEC pressure switch, so one can be added... It will work on any D series VTEC engine... The only reason I removed it was because I used a P28 and had another VTEC solenoid with the pressure switch... Make offers...
Old Nov 8, 2005 | 12:28 PM
aarontrini85's Avatar
Default Re: SOHC VTEC Solenoid 92-95 Civic D16Z6 D16Y8 D15B (Exempt)
i think i just saw this on ebay like a direct quote lol but how mutch do these go for??? becous i need one
Old Nov 8, 2005 | 01:04 PM
Exempt's Avatar
Yea, I just relisted it on there, its my auction... Im honestly not sure what they go for... So I put a minimum bid of $5.00 on the auction...
http://cgi.ebay.com/ebaymotors...33617
Old Nov 8, 2005 | 01:10 PM
Default Re: (Exempt)
i threw a low bid on there hopefully it goes up to what is resinalbe i dont want to rip you off but then again dont want to over pay
if any one can let us know what is fair for this let us know
KaliKid
Jun 13, 2014 04:30 PM
excivicboy96
12
Aug 2, 2007 09:29 AM
AdamITR
Apr 14, 2003 04:38 PM
InfamousRS
May 21, 2002 04:09 PM
