speedo not working
Old Nov 7, 2005 | 05:46 PM
aka's Avatar
aka
Default speedo not working
We just but a b16 in a 90 crx dx and took it for a test run and the speedometer was not working. Because the speedo was not working, I didn't expect vtec to work either but it does. I've double checked the cable going into the tranny and it seems to be in there snug. We are not throwing the VSS code either. Your thoughts???
Old Nov 7, 2005 | 05:53 PM
180MPHGUY's Avatar
do you have the cable all the way in, theres a slot that you have to line up to put it all the way in, and I'm pretty sure you dont need the speedometer to hit vtec on 4th gens
Old Nov 18, 2005 | 01:13 PM
aka's Avatar
aka
cable is all the way in. I have vtec. I start seeing the speedo working when Im doing about 60-70mph but it only reads as if Im going 10mph. I'll take it up to around 80mph and it will read 30mph. I checked the blue wire on the dizzy and its pushed in. What else should I be looking at.
Old Nov 19, 2005 | 12:45 PM
phyzJunkieCivic's Avatar
From: Dont You Just Love Lynn Cops, Boston MA, USMA
i got a quetion speedo dont work would vtec work?
Old Nov 19, 2005 | 02:25 PM
Mr. lonly's Avatar
Default Re: (phyz)
some times the read mount does not let cable go all the way in or check the part on the trany where the calbe plugs in to, it may not be good, ur cable need to be change.
Old Nov 22, 2005 | 05:18 AM
problem solve it was the cable connector it was rotted . took 2 from the junk yard
Modified by phyz at 10:14 AM 12/5/2005
Old Dec 5, 2005 | 06:23 AM
Default Re: (phyz)
[IMG][/IMG]
Old Dec 5, 2005 | 06:29 AM
65stang90crx's Avatar
Default Re: (phyz)
^^^ Wow dude thats an expensive ticket!! Wouldve been cheaper to keep it on the track!!
Old Dec 5, 2005 | 07:28 AM
EJ1 wilcox's Avatar
Default Re: (65stang90crx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 65stang90crx &raquo;</TD></TR><TR><TD CLASS="quote">^^^ Wow dude thats an expensive ticket!! Wouldve been cheaper to keep it on the track!!</TD></TR></TABLE>
LoL. No doubt.
Here at PIR it's $20 to race all night!
Sucks to hear about that ticket. That's a lot of money.
integra95gsr's Avatar
where do you plug the speedo cable in on the b16?
Old Dec 5, 2005 | 12:16 PM
bump....
Old Dec 5, 2005 | 02:52 PM
31flavorscivic's Avatar
Default Re: (integra95gsr)
God DAMN that's what I bought my car for!!!!!!!!!!!!!111one
Old Dec 5, 2005 | 04:26 PM
SoClose's Avatar
Default Re: (phyz)
speedometer and v-tec is a complete different thing . . the speedometer is being controlled by the VSS ( Vehicle Speed Sensor ) which indicates what ur MPH/Kilometers wether the engine is electrical or cable, also if the clusters are cable or electrical, then v-tec ( Variable valve Timing Electronic Control lift ) is engine based which ignites when the engine reaches a certain RPM ( revolutions per minute )
Old Dec 5, 2005 | 05:30 PM
Default Re: (S o C l o s e)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by S o C l o s e &raquo;</TD></TR><TR><TD CLASS="quote">speedometer and v-tec is a complete different thing . . the speedometer is being controlled by the VSS ( Vehicle Speed Sensor ) which indicates what ur MPH/Kilometers wether the engine is electrical or cable, also if the clusters are cable or electrical, then v-tec ( Variable valve Timing Electronic Control lift ) is engine based which ignites when the engine reaches a certain RPM ( revolutions per minute ) </TD></TR></TABLE>
ACTUALLY... In the newer cars, vtec depends on a few conditions. Not all of these are new, but besides the fact that it required a certain RPM, it now requires that the car be going faster than ~20 MPH, that oil pressure be good, that the car is warmed up, and that the throttle position is greater than around 80%. Just FYI. I guess in the old ones speed wasn't a requirement, but that's where he was coming from.
louevilhatch
Jul 12, 2007 05:11 PM
in10ceCiviC
Mar 4, 2007 12:53 PM
fastcat1
Dec 31, 2002 01:13 PM
dingusjt
Jun 30, 2002 09:34 AM
