z6 with y8 cam gear
Old Nov 7, 2005 | 02:39 PM
gnar kill's Avatar
Default z6 with y8 cam gear
ok guys I got a z6 that has a y8 cam gear on it....I know the z6 and y8 cam gears are slightly different. this is what I know
http://www.d-series.org/forums...=gear
check that site out that is where I am gettin most of my info
I picked up a JG adjustable cam gear for 40 bucks off some guy on here and it is also for the y8. Now where do I set it to to set it at TDC when the crank is at TDC....I am thinkin 4 degrees retarded but I am not sure
this is my first post in the eg forum I am an ef kid so thanx for the help guys
Casey
Old Nov 7, 2005 | 04:17 PM
gnar kill's Avatar
Default Re: z6 with y8 cam gear (gnar kill)
this is a good tech related question....and I hope it is obvious that I have searched. anyone else on here doing this??
Old Nov 8, 2005 | 10:20 AM
gnar kill's Avatar
bump....
Old Nov 8, 2005 | 11:07 AM
gftgrill's Avatar
aprox. 4.5 degrees retarded
Old Nov 8, 2005 | 03:03 PM
gnar kill's Avatar
Default Re: (gftgrill)
ok when I set it to that...I got to line the thing up and no matter what I do the cam and crank always seem to be about exactly half of a tooth off......should I set the cam gear to 0 and TDC the thing and then get it lined up and then retard the cam gear 4.5 degrees?
Old Nov 8, 2005 | 04:47 PM
gftgrill's Avatar
retard the gear first. then put it on. then install using the tdc mark on the gear.
Old Nov 9, 2005 | 08:55 AM
gnar kill's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gftgrill &raquo;</TD></TR><TR><TD CLASS="quote">retard the gear first. then put it on. then install using the tdc mark on the gear.
that is what I have been doing and it always seems to be off by half of a tooth....
Old Nov 9, 2005 | 09:34 AM
gftgrill's Avatar
well when you retard the gear it's going to move the outter part aprox. 1/2 tooth.
Old Nov 9, 2005 | 03:28 PM
gnar kill's Avatar
yeah that is why I think I am goin to try and zero it because the teeth line up and then retard the thing....( I would have tried by now but I only go work on my car on the weekends)
viskii420
Jan 11, 2009 12:20 PM
nikolass
Oct 4, 2006 08:33 AM
SOHC_MShue
Feb 7, 2004 06:18 AM
