"rumbling" at 30mph - 97 civic
Old Nov 7, 2005 | 11:18 AM
jennabee's Avatar
Default "rumbling" at 30mph - 97 civic
Hi...another question for you all. Again, I have a 97 civic ex.
Lately, I've been noticing when I travel at roughly 30mph (light touch on accelerator to maintain speed), I occasionally get a "rumbling" feeling from the front end....similar to that when you drive over rumble strips. It doesn't happen always, but this seems to happen at 30mph and mild acceleration.
I'm wondering if this is transmission? My dad thought it was something with a tire buldge? I'm at a loss.
Thanks for any help you can offer.
Old Nov 7, 2005 | 01:05 PM
jennabee's Avatar
Default Re: "rumbling" at 30mph - 97 civic (jennabee)
nudge
Old Nov 7, 2005 | 01:21 PM
Slow EJ8's Avatar
Few things to check:
-Alignment
-Tires for buldges like you mentioned or maybe get them balanced
-something bent in suspention
That should get you started.
Also, If you think its the trans try going that speed (30mph you said) in different gears and see what happend. Like try gears 2, 3, 4 and even neutral if possible. Maybe that would shed some light on something.
Old Nov 7, 2005 | 01:24 PM
jennabee's Avatar
Default Re: "rumbling" at 30mph - 97 civic (Slow EJ8)
Things I should have mentioned....it's an automatic. But thanks for the leads....!
Old Nov 7, 2005 | 03:26 PM
sockvtec's Avatar
take your wheels off and make sure everyhting is connected right
Old Nov 7, 2005 | 03:40 PM
B7AudiA4's Avatar
Hmm i have a 00 4 door automatic... similar to yours i guess...
does it sound like a tranny problem or suspension problem?
because the way your describing it.. the "rumbling strip" noise...
Probably it's the ride feeling/alignment =X
Old Nov 14, 2005 | 02:41 PM
93Sivic's Avatar
alignment????
Old Nov 15, 2005 | 09:31 PM
sockvtec's Avatar
Default Re: "rumbling" at 30mph - 97 civic (93Sivic)
bump again cause its starting to happen to my car
alexsinor
Transmission & Drivetrain
Jun 11, 2013 11:08 AM
