PLX-M300 install Q
Old Nov 7, 2005 | 09:25 AM
ej2civic's Avatar
Default PLX-M300 install Q
OK.
Just got this thing today.
Im looking at the manual. It says, connect the 12V source as near ECU as possible. This power should be only be supplied when the key is turned past specific position. Make sure this connection is capable of supplying at least 3Amps.
Is there some good source near ECU. Or can I connect it to ECUs own source?
I already have Apexi VAFC connected...
Old Nov 7, 2005 | 09:29 AM
Luserkid's Avatar
Default Re: PLX-M300 install Q (ej2civic)
I would connect it before the VAFC if you can. Then have the VAFC power after it.
Old Nov 7, 2005 | 09:30 AM
dohcdelsol93's Avatar
I hooked mine up at the key switch along with the turbo timer and don't have any problems. That was the only power source I could find with the key in the on position without standing on my head and doing some hardcore searching. However I don't use mine for tuning, only o2 reading.
Old Nov 7, 2005 | 09:46 AM
ej2civic's Avatar
Default Re: PLX-M300 install Q (Luserkid)
Dont quiet understand you Can you/someone post diagram?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid &raquo;</TD></TR><TR><TD CLASS="quote">I would connect it before the VAFC if you can. Then have the VAFC power after it. </TD></TR></TABLE>
Old Nov 7, 2005 | 09:49 AM
Luserkid's Avatar
Who installed your VAFC?
VAFC taps into the ecu wires like your wideband manual tells you to. So you want to put the wideband before the VAFC wires.
Old Nov 7, 2005 | 10:08 AM
ej2civic's Avatar
I installed :D OK Ill do it that way. thanks...
Old Nov 11, 2005 | 02:48 PM
ej2civic's Avatar
OK. Installed this device today.
Where do I put that oxygen sensor heater 20ohm/10W "cheater" resistor?
Old Nov 11, 2005 | 03:39 PM
mike93eh
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ej2civic &raquo;</TD></TR><TR><TD CLASS="quote">OK. Installed this device today.
Where do I put that oxygen sensor heater 20ohm/10W "cheater" resistor?</TD></TR></TABLE>
from ladysman:
Take a dead O2 sensor and cut the wires. SOlder the resistor on the ground wires. Heat shrink or tape. Done.
https://honda-tech.com/zerothread?id=1422548
Old Nov 12, 2005 | 01:14 AM
ej2civic's Avatar
Default Re: PLX-M300 install Q (mike93eh)
But my dead o2 sensor has 2white 1gray 1black wire???
Gonna street tune it on WOT to 13.0-13.2 and cruise to 14.7...
GreddyCivic7
Dec 27, 2006 05:08 PM
sublimenerd
Oct 23, 2006 12:37 PM
krystianitr
Dec 27, 2004 10:57 AM
domepizzle
Jan 1, 2003 03:43 PM
Mugen Dom
Apr 4, 2002 11:28 AM
