Plug wire keeps popping out
Old Nov 7, 2005 | 08:45 AM
jsrusse11's Avatar
Default Plug wire keeps popping out
my number 2 cylinders spark plug keeps popping out. so i crimped the metal a little to make it hold tighter but it still pops up. its on a 1.5 L.
Old Nov 7, 2005 | 08:55 AM
Slowboy!'s Avatar
Default Re: Plug wire keeps popping out (jsrusse11)
What do you mean you crimped the metal together
Curt
Old Nov 7, 2005 | 09:07 AM
KayOs's Avatar
what kind of wires are you using? I would highly suggest using stock wires if you are not already .....
Old Nov 7, 2005 | 09:09 AM
dpetro1's Avatar
Default Re: Plug wire keeps popping out (KayOs)
i had this problem when trying to use some cheap pep boys wires on my old toyota celica. use oem wires or ngk
also i guess you could make sure the plug itself is in good shape
Old Nov 7, 2005 | 12:23 PM
jsrusse11's Avatar
Default Re: Plug wire keeps popping out (dpetro1)
i smashes the metal that goes around the spark plug itself so it would hold tighter. new plugs and don't know what kind of wires. what are good ones to get for a good price and were if i decide to replace them.
Old Nov 7, 2005 | 12:27 PM
dpetro1's Avatar
OEM or NGK
Old Nov 7, 2005 | 12:41 PM
civic_driver's Avatar
make sure the plug wires have a hole so that no pressure builds up and pop the wire as you're experiencing... if they don't make one using a needle or something sharp
check out the following diagram:
Old Nov 7, 2005 | 12:44 PM
Ricey McRicerton's Avatar
OEM wires.
Old Nov 7, 2005 | 05:05 PM
jsrusse11's Avatar
Default Re: Plug wire keeps popping out (Ricey McRicerton)
I'll try the hole thing i don't remeber seeing one. if not how much are oem or where can i find ngk?
Old Nov 7, 2005 | 05:09 PM
TurboASR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ricey McRicerton &raquo;</TD></TR><TR><TD CLASS="quote">OEM wires.</TD></TR></TABLE>
Only the best
Old Nov 7, 2005 | 05:20 PM
sh!tsWEAK!'s Avatar
Default Re: Plug wire keeps popping out (VTHONDABOY)
Get some fresh OEM wires
Supahr_Ed
17
Jun 3, 2007 08:37 PM
dkrex001
Oct 4, 2006 03:18 PM
srv3fender
15
Mar 23, 2005 09:09 AM
EzKV
Mar 17, 2004 01:56 PM
newblueteg
Apr 1, 2003 04:13 PM
