Which ECU to use for z6 swap
I found a good deal on a z6 with wiring harness and im pretty sure i need to pick up a p28 ecu. I've searched and havent found a clear answer as to whether or not the stock ecu ( 95 cx) will work, any input?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedcivicsir »</TD></TR><TR><TD CLASS="quote">the cx ecu will work temporarily if you wire in a single wire o2.
but to do it correctly, you will need a p28.</TD></TR></TABLE>
agreed, a P05(CX) will start and run a z6, but don't run it very long. You'll also be missing VTEC.
A P28 is the best bet, with a 4-wire O2 of course.
i actually broke my current b16 in on a stock dx ecu because all i had was a 750cc base and it was a little too fat for my liking. if you had a dx ecu that would be a little better. but the p28 is the ecu you need.
no_rice_please
Feb 25, 2007 07:29 PM
