over cooling?
Old Nov 6, 2005 | 10:05 PM
TeamInlineB18B's Avatar
Default over cooling?
okay well crx w/b16 when i got it it would idle at normal temp but as soon as the revs go up the temp goes down... i replaced the thermostat and its still doing it... rigtht now on the freeway the car drives all the way to C. could it be something to do with skunk2 intake manifold? could it be the sensor? i already bleed the system like 4 times... anybody got any ideas???
Old Nov 7, 2005 | 03:29 PM
Antilag's Avatar
Default Re: over cooling? (TeamInlineB18B)
Sounds like a bad ect sensor.
Old Nov 7, 2005 | 06:23 PM
Takumi Fujiwara's Avatar
Default Re: over cooling? (9sech22civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 9sech22civic &raquo;</TD></TR><TR><TD CLASS="quote">Sounds like a bad ect sensor.</TD></TR></TABLE>
I don't know if that's the actual name for it, but yea, it definitely sounds like the 1-wire temp sensor.
Old Nov 9, 2005 | 01:27 AM
wheres the sensor at?
Old Nov 9, 2005 | 04:00 AM
JimBlake's Avatar
Default Re: (TeamInlineB18B)
On the end of the head, near the distributor. The ECT sensor has a 2-wire plug, and that's for the ECU, but that's not the one. Nearby is a smaller sensor with only one wire, that's the sender for the temperature gauge, which is the one you want.
710dabber
Nov 5, 2015 12:36 PM
orioncivic
Sep 3, 2008 07:50 PM
foress_89
Jan 15, 2008 03:58 PM
davidluko
Nov 19, 2006 08:27 AM
Adam_F123
Mar 18, 2004 05:18 AM
