B20/VTEC Almost finished... Where do I get oil from?
Old Nov 6, 2005 | 02:34 PM
knoj's Avatar
Default B20/VTEC Almost finished... Where do I get oil from?
Ok, my B20/VTEC swap is almost done, and I got all of my stuff... I dropped $80 on 4AN fittings and SS Hoses, and in my haste (and excitement), I put the head on. Now I can't get to the fitting that holds what I believe is the oil temp sensor? Well, regardless of what it is, it's on the back side of the block... Is there a more accessable place to get oil pressure from? I don't want to take the head back off...
I did search, but was unsatisfied with the results found.
Thanks in advance for any help you can provide.
Old Nov 6, 2005 | 02:39 PM
Soccerking3000's Avatar
Default Re: B20/VTEC Almost finished... Where do I get oil from? (knoj)
get a sandwich adapter plate that goes between the oil filter and block, greddy and GE make them makes everything 100 x easier
Old Nov 7, 2005 | 03:21 AM
knoj's Avatar
Default Re: B20/VTEC Almost finished... Where do I get oil from? (Soccerking3000)
I appreciate the idea, but for the $80+ for the sandwitch adapter, I'll just take the head back off... I didn't know if there was a more accessable plug in the block that had oil pressure behind it.
Anyone know if there are any other options?
Thanks,
Old Nov 7, 2005 | 05:30 AM
si0385.'s Avatar
http://www.inlinefour.com/gredoilfilbl.html
its soo much easier than taking the head off and its not 80 its $57
b204dr's Avatar
tapping your own genrally dosnt work as well as the sandwich adapter
Old Nov 7, 2005 | 06:26 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by knoj &raquo;</TD></TR><TR><TD CLASS="quote">I appreciate the idea, but for the $80+ for the sandwitch adapter, I'll just take the head back off... I didn't know if there was a more accessable plug in the block that had oil pressure behind it.
Thanks,</TD></TR></TABLE>
you also run the risk of the fitting snapping off inside the block and losing all of your oil, the sandwich adapter is a fairly cheap and very effective way of connecting oil lines, oil pressure and temp sensors
Old Nov 7, 2005 | 06:48 AM
Stripped Honda's Avatar
99-0104
the sandwitch adapter is 57 bucks and a new headgasket is about 50 bucks ... i think i would rather buy the adapter .... unless you plan on using the head gasket again
Old Nov 7, 2005 | 08:50 AM
petersayarath's Avatar
thanks for the site.. thumbs up
Old Nov 7, 2005 | 02:49 PM
knoj's Avatar
Default Re: B20/VTEC Almost finished... Where do I get oil from? (Stripped Honda)
Thanks everyone! However... I couldn't wait. I had not yet torqued the head down yet, so I opted to pull it again and see if I thought the gasket was useable... It didn't look any different than it did new, I just went to the local machine shop and they had some 1/4" to 4AN adapters, so I was back in business. I wanted to get this project done as quickly as possible... I only get a few good hours of daylight now that winter is on it's way. In less than a month I'll have a garage (and a house to go with it), but I want to have this sexy beast back on the road in time to drive it there (once before snowfall anyways).
Thanks everyone!
Old Nov 15, 2005 | 04:28 PM
knoj's Avatar
Update... The engine runs so well, much more smoothly than it did before I took the B20 head off! Thanks everyone for the help!
ProricanEF
Apr 4, 2011 07:55 PM
gsr_b20x2
Jul 14, 2005 12:16 PM
10K2HVN
Apr 23, 2003 07:21 AM
B20-T
Jul 24, 2002 05:37 AM
EkREV
Oct 7, 2001 09:37 AM
