LOW IDLE>>>>>>>>
Old Mar 9, 2002 | 02:27 PM
civicboy95's Avatar
Default LOW IDLE>>>>>>>>
hey guyz, i got a slight problem. i installed my iceman CAI on my 95 civic coupe. now my idle is at 200. it's supposed to be 600-900. how do i fix this? thanx
Old Mar 9, 2002 | 02:38 PM
DragII's Avatar
25 Year Member
Default Re: LOW IDLE>>>>>>>> (civicboy95)
did you forget to install any hoses?? sounds like a vac leak.
Old Mar 9, 2002 | 02:44 PM
kefka's Avatar
Default Re: LOW IDLE>>>>>>>> (EvilDragII)
you can adjust your throttle screw....
Old Mar 9, 2002 | 02:59 PM
civicboy95's Avatar
Default Re: LOW IDLE>>>>>>>> (madeinjapan)
i dont know how to reset the ECU. can anyone tell me? for a 95 civic ex coupe. whats the other method other than disconnecting battery? what fuses do i all need to pull out?
Old Mar 9, 2002 | 03:01 PM
DragII's Avatar
25 Year Member
pull the fuse that says back up, or ecu on under the hood
Old Mar 9, 2002 | 03:16 PM
deepnite's Avatar
u can reset ur ecu by disconnecting the battery and let it stand a few mins. then start it up again and let it run for about 15 mins on idle..or perhaps ur getting more air now and u need to boost ur octane
BigECivic
Aug 9, 2011 05:13 PM
burntkookie
Oct 14, 2009 01:08 AM
sonicblueteg2k
Apr 29, 2003 04:52 PM
GS-Rcivic
Jan 8, 2003 09:29 AM
VtecInteg95
Oct 27, 2002 09:06 PM
