need help B16
this is all i got. trying to put in my civic the guy i got it from said i can use my D16 engine harness is it true? Can i use axle's from a B16 off 99 civic si? what else do i need before i start the swap? thanks
[Modified by si foo, 11:04 PM 3/9/2002]
okay did you get the rear mount too?? It kinda looks like its allready connected in the bottom picture but i'm not sure!! also axles from the new si will work if you get the new si halfshaft!! You can use you d16 harness just have to add the wires for vtec!! Yeah, you will need shift linkage, rad hoses, throttle cable, and don't forget your fluids!! There might be some other stuff i forgot, but i'm sure someone else will mention it!!
LSegHatchy
Jul 12, 2009 12:10 PM
hondatuner020
12
Dec 27, 2007 06:32 AM
