New Setup Questions
Alright well as Most of you know, (becuase my lame thread has been ttt recently).. My motor has lost compression in 1 cylinder (140)... and i did a wet compression test and it resulted good (no blown rings .. hopefully)...Anyways, I pickied upa new head and i will be doing a head swap (with abuilt one), change headgasket.. and POSSIBLY... cahnging the pistons (my buddy says u can do it when the motor is still in the car. and i have a few questions on the setup.
My motor has 134K on it. If i were to get new pistons (either OEM or TYPE S)... I should get brand new of course but is it worth it to get the type s's.. Where are places i can buy OEM pistons and OEM type s pistons and rods?
My setup (hopefully)
Type S pistons + new rods
JG engine dynamics head
Crower valvesprings + retainers
Upgraded Cams
adj cam gears
JUN flywheel
Exedy clutch
apexi intake
MR header with 2.25 collector
2.25 crush bent
2.36 rsr ex mag exhaust
NGK blues
Chipped P28 ( uberdata)
Hows that set up sound?
sohould i get a Higher compression headgasket? (Cometic?)
other things i should do when i do the headswap (besides timing belt, balance belt, water pump)
Upgraded Cams
adj cam gears
JUN flywheel
Exedy clutch
apexi intake
2.25 crush bent
NGK blues
You can, but unless you use OEM pistons and have a good cylinder wall left, I would pull the motor. I wouldn't feel bad about using OEM-style pistons and new rings w/o a hone, if the cylinder walls aren't scratched and they're spec'd out to get the right pistons.
To replace pistons w/ the motor still in the car: drop oil pan/windage tray/girld/mains, remove head. Unbolt rod caps from crank and rotate crank out of the way for each bore. Pull piston/rod out through top. Reinstall is the opposite.
id imagine you would want the block to be honed at a machine shop.... where it would be fastened down. and done with a press... doing it by hand... i wouldnt try.. if you move slightly.. lean.. tip what ever.. the hone will be uneven and will most likely have sealing problems... not something i would try..
Kingpin, if your cylinders are in good shape (bore roundness and taper) you can use a flex hone to touch up the cross hatching if you are just chaning to new pistons or rings. You shouldn't use a flex hone if your cylinders are out of round, need to be overbored even slightly, or are tapered and need to be re-machined.
For anyone thinking about it... I did the piston/rod swap with the engine still in the car on my first car, it was a major pain, if you're already pulling the pan, head, accessories etc, why not just rent or borrow lift for a couple days you'll have much more space, you'll work faster, and more accuratley, in the end its worth the 30 bucks. just a happy thought
good luck!
good luck!
.....yeah, I'll just go ahead and take the engine out. They're probably out of round anyway. Thanks for the info.
Edit: Ah ****, I'm sorry man. I didn't mean to thread jack. I'll delete my posts.
kainoner
18
Mar 31, 2009 09:46 PM
