how to remove a really ($*(#)$*)(#$)# $#*$(*# pulley?
Old Mar 9, 2002 | 11:35 AM
schwett's Avatar
New User
Default how to remove a really ($*(#)$*)(#$)# $#*$(*# pulley?
this is driving me absolutely crazy. does anyone have any suggestions on how to remove this pulley :
i went to SIX auto parts and tool shops. no gear puller any of them had or knew of would fit in there because of the perpendicular proximity to the valve cover, the small size of the pulley, the lack of a pronounced "flange," and the proximity of the valve cover and other parts of the motor.
i'm not talking about one or two gear pullers, i'm talking about 10-12 different types in all. the ones with the cages, the perpendicular arm types, the S arm types, etc etc.
further, it's not being held in place by some momentary bond. i did, after breaking 2 more screwdrivers and bending the hell out of a 1/8" flat bar steel pry bar, manage to move it approximately 1/32 of inch. it is just as hard to move now as when it was in it's original position.
i tried penetrating oil, no effect (it doesn't really "penetrate"), a hair dryer to heat it up, pounding from various angles, pulling, twisting, and prying. the inside of the pulley should look just like one, totally smooth with a single keyway :
i don't understand how it could fit SO tightly just with friction... but it does.
[Modified by schwett, 12:35 PM 3/9/2002]
Old Mar 9, 2002 | 01:56 PM
mantic6t9's Avatar
Default Re: how to remove a really ($*(#)$*)(#$)# $#*$(*# pulley? (schwett)
Have you tried taking if off when the engine is hot. This may help because metal expands as it's heated.
Old Mar 9, 2002 | 02:18 PM
schwett's Avatar
New User
Default Re: how to remove a really (mantic6t9)
yeah, it was REALLY hot last time i tried. i suspect the differential heating of the steel and aluminum is not working in my favor...
Old Mar 9, 2002 | 06:54 PM
1 2 NV's Avatar
Default Re: how to remove a really (Teken)
BFHs rule.
Old Mar 9, 2002 | 09:52 PM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: how to remove a really (hondaatwsu)
BFHs rule.
Yup, gotta love the BFH!!
Old Mar 9, 2002 | 10:34 PM
schwett's Avatar
New User
thanks for the suggestions.
1. i am not retarded!! obviously, i removed the belt and removed the very obvious bolt and washer. there is NOTHING holding this thing on but friction.
i have given up and basically need to remove the whole assembly (which includes removing the ()$*#)($#)( supercharger) and just purchase a new one. there is no force i can cause to be applied to this object that will remove it.
to wit : i found a gear puller that i could engage the pulley with. just by chance the rotating lever that clamps the arms in spins in one of the bolt recesses on the valve cover. i had to hacksaw off 1/2 of the T arm in order to let it turn, but it works. using approximately one foot of moment, i cranked that ****** down on the pulley. then using the same giant pliers, i rotated the push screw on the gear puller. net result? the pointed end of the puller gouged a 1/8" deep recess into the solid steel end of the jackshaft bolt. i removed the puller and filed the end down to a 1/4" flat nub. repeated process. the puller tore right through the flange on the pulley.
this is really ****** ridiculous, and i am pissed off. there must be something wrong with the design of this crap to cause a nonthreaded keywayed object to be so difficult to remove.
penetrating oil did not penetrate even in the slightest, as far as i could tell. i doped it up pretty good on the only available seam.
Old Mar 10, 2002 | 04:39 AM
owen_the_soyboy's Avatar
Default Re: how to remove a really (schwett)
any suggestions from the manufacturer?
a lot of tapping froma bfh on that outer lip in the direction you want the pulley to move should do th etrick.
LOL, you tried to heat it up with a hairdryer? try a torch!
Old Mar 10, 2002 | 04:41 AM
dustin's Avatar
Default Re: how to remove a really (owen_the_soyboy)
This will remove the pulley:
Old Mar 10, 2002 | 09:22 AM
earl's Avatar
Default Re: how to remove a really (dustin)
Sounds like the pully is ruined. Why not take a grinder and cut some slots in what's left of the pully and split it apart with your BFH. That will teach it a lesson
Old Mar 10, 2002 | 09:37 AM
schwett's Avatar
New User
Default Re: how to remove a really (earl)
that's not a bad idea. i wonder if my dremel will do it.
Old Mar 10, 2002 | 10:04 AM
91DA9's Avatar
Oxy-acetylene torch should do the trick
Old Mar 10, 2002 | 10:11 AM
schwett's Avatar
New User
Default Re: how to remove a really (94IntegraGSR-OVR)
i'm wary about open flame 1" from my fuel rail and main fuel line (rubber!)
Old Mar 10, 2002 | 12:47 PM
fixhondas's Avatar
Remove the bracket it is bolted to and use a bearing splitter and a press.
[Modified by fixhondas, 4:49 PM 3/10/2002]
eg_h22
Oct 15, 2007 04:14 PM
swindler86
Oct 31, 2005 11:29 PM
H22LudeLover
Aug 23, 2005 07:36 PM
mrrealiztek
Aug 2, 2004 08:56 PM
originalbadbob
17
May 27, 2004 12:34 PM
