stalling help
alright guys need some help, 98 type-r with ls/vtec motor fully built high compression. here's the problem. the car starts and runs perfect for about 20-40 sec. then dies. vehicle has fuel pressure, spark, and is timed correctly. no check engine light is illuminated. checked the simple things already plugged cat. and such. no two simple questions. first if the entire fuel system is working correctly and you have the key on without the engine running and you crack the 22mm nut loose on the filter side of the fuel rail. how much fuel should come out and second thing is does anyone have any other suggestions on what it could be. Need help ASAP. thanks
weirdone86
Sep 14, 2006 07:35 AM
hair_rice
Jul 5, 2004 07:37 PM
