motor mounts + high hp h22's
Old Nov 5, 2005 | 01:52 PM
h22turboCL's Avatar
Default motor mounts + high hp h22's
Any boosted ludes in here having problems with their stock motor mounts holding up due to the increase of power?
Anyone upgrade their motor mounts? or perhaps with urethane inserts?
Old Nov 5, 2005 | 01:57 PM
MadCityLude
Guest
Posts: n/a
Default Re: motor mounts + high hp h22's (h22turboCL)
I have already went through a couple mounts myself. I am getting inserts next week. First my front and rear, now just my front. So when I get the front replaced again I am adding Energy Inserts. Worth a shot! I can't find any aftermarket mounts available.
Old Nov 5, 2005 | 02:22 PM
LudeyKrus's Avatar
Just go get the polyurethane from Lowe's and do a DIY filled mount set. It'll cost you $5 and a few hours of your time.
Old Nov 5, 2005 | 03:29 PM
MadCityLude
Guest
Posts: n/a
Default Re: (LudeyKrus)
How do you do it exactly? I am interested in this for sure
Thanks
Old Nov 5, 2005 | 03:53 PM
clemsoncb7's Avatar
Default Re: (92_JDM_VTEC_lude)
its actually pretty easy, you have to boil down the urethane and then pour it into the mount(seal one side) and let it sit overnight or something, its not hard...
Old Nov 5, 2005 | 03:56 PM
LudeyKrus's Avatar
Not even that much.
Search on here in all forums for DIY Motor Mounts. It will explain it all. I believe you actually use a tube of roofing adhesive that is a black polyurethane, and when hardened is around 90A. You just remove mounts, tape up one side, squeeze in poly, let it dry, reinstall.
EDIT - Here's the link:
https://honda-tech.com/zerothread?id=445236
Old Nov 5, 2005 | 04:13 PM
The Weather Man's Avatar
what kind of horsepwoer and torque numbers are obtained before actually experiencing motor mount problems....i might have to add this into my schedule here pretty soon.
Old Nov 5, 2005 | 04:14 PM
chitownrida's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LudeyKrus &raquo;</TD></TR><TR><TD CLASS="quote">Just go get the polyurethane from Lowe's and do a DIY filled mount set. It'll cost you $5 and a few hours of your time.</TD></TR></TABLE>
buy polyurethane sealer (might be called window weld) comes in a tube like caulk
fill em.
make sure you are runnin all the mounts too.. i ran without a front one for a while and the motor shifts alot with out a front mount
Old Nov 5, 2005 | 04:43 PM
h22turboCL's Avatar
my friend mentioned that to me and i think im going to do that
Old Nov 5, 2005 | 08:59 PM
mgags7's Avatar
the energy mounts only cost 20 bucks....
Old Nov 5, 2005 | 09:26 PM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
Default Re: (mgags7)
window weld is ok, but doesnt hold up in the heat too well(engine bay temps.) I window welded(??) my mounts and they lasted about 1 year and a half then started cracking. I might try that roofers urethane next.
Old Nov 6, 2005 | 11:53 AM
ed_1's Avatar
Default Re: (cb7-R)
Go with the energy suspension polyurethane motor mounts, they sell them on ebay like around $40 shipped. I want to get some but i've been laggin it. I heard they make a noticeable difference.
Old Nov 6, 2005 | 01:31 PM
LudeyKrus's Avatar
I've got the ES inserts on my Prelude right now and like them. They were less than $20 for me. Honestly, if you're not into taking a few hours for the job, this is a close-enough solution.
For MR2's, though, the same inserts run over $40-50.
Old Nov 6, 2005 | 06:35 PM
BokChoy's Avatar
are those mounts pictured on ebay with the bushing kits just for show or does it actually come with mounts as well. Secondly how hard is it to push out the factory rubber bushings. Lastly is there a factory replacement set of billet mounts just as an upgrade.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mgags7 &raquo;</TD></TR><TR><TD CLASS="quote">the energy mounts only cost 20 bucks....</TD></TR></TABLE>
Old Nov 6, 2005 | 06:43 PM
plikit's Avatar
Default Re: (ed_1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ed_1 &raquo;</TD></TR><TR><TD CLASS="quote">Go with the energy suspension polyurethane motor mounts, they sell them on ebay like around $40 shipped. I want to get some but i've been laggin it. I heard they make a noticeable difference. </TD></TR></TABLE>
energy suspension makes good stuff. i replaced upper and lower control arm bushings in the front. great quality. i think its easier getting the old mounts out than getting the new ones in.
Old Nov 6, 2005 | 07:56 PM
mgags7's Avatar
the es motor mount inserts are just inserts...they fit around the stock rubber....you dont push anything out...
i wonder if the tq is really worth the shaking....i hate rattling ****...
Old Nov 7, 2005 | 06:16 AM
LudeyKrus's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mgags7 &raquo;</TD></TR><TR><TD CLASS="quote">the es motor mount inserts are just inserts...they fit around the stock rubber....you dont push anything out...
i wonder if the tq is really worth the shaking....i hate rattling ****...</TD></TR></TABLE>
The increase in shaking isn't that bad, at least it wasn't bad at all for me when I got the inserts and removed the balance shaft belt.
Now the open header dumping right underneath me causes my throat to thump
Old Nov 7, 2005 | 06:42 AM
syntax.'s Avatar
Now the open header dumping right underneath me causes my throat to thump </TD></TR></TABLE>
I have es motor mount inserts, front and rear, and the balance shaft belt removed. The engine vibrates like a lonely housewife!! when its idling, i can visibly see the front bumper vibrating and everything rattles. it sucks. Maybe i overtorqued the motor mount bolts or something, but its really annoying. Im thinking about replacing mounts with new ones from honda and skipping the inserts.
Old Nov 7, 2005 | 07:21 AM
pentaq's Avatar
Default Re: (syntax420)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by syntax420 &raquo;</TD></TR><TR><TD CLASS="quote">
I have es motor mount inserts, front and rear, and the balance shaft belt removed. The engine vibrates like a lonely housewife!! when its idling, i can visibly see the front bumper vibrating and everything rattles. it sucks. Maybe i overtorqued the motor mount bolts or something, but its really annoying. Im thinking about replacing mounts with new ones from honda and skipping the inserts.</TD></TR></TABLE>
The same here... Or at least I'll use only one mount insert set (front).
hondaapi
Oct 20, 2008 01:52 AM
NAmodified
Oct 16, 2007 08:35 AM
zx2gotboost
Nov 28, 2005 10:33 PM
Bbasso
Mar 4, 2005 05:48 PM
6GACCORDH22
Sep 11, 2002 06:01 AM
