b18b swap questions
yea u should get the ecu to match because the d series ecus tend to run the b series motors a lil lean. as for the wiring harness im not 100% sure so im not gonna guess for u. well what are u putting it in? is the motor swap the same obd? is your car obd1 or obd2? Need more info to help u out man
Sorry bout that. I am going to be using a 94 del sol, i believe that it had the d16y8 motor in it before, I don't know because the motor has been already pulled. Swapping in a b18b. What would I need wiring wise?
.::miLan
Nov 15, 2005 10:06 PM
.::miLan
Nov 15, 2005 05:43 PM
