Clutch is stuck to the floor?
Old Nov 5, 2005 | 11:14 AM
sniperslayer's Avatar
Default Clutch is stuck to the floor?
last night while driving my clutch went down, but wouldnt come back up unless i did it by hand...
once i pulled it up by hand and stepped on it again, i could then get it into gear
but after that driving home, i cant even get it into gear now when i push it down, it just goes down to the floor and the clutch is not engaged what so ever
i had to Slam it into 2nd to drive it home last night.....
so what could be the problem? is there some kind if linkage that the pedal is connected to that could be loose?
Old Nov 5, 2005 | 11:17 AM
-Gambit-'s Avatar
Default Re: Clutch is stuck to the floor? (sniperslayer)
check your fluid and bleed your clutch
Old Nov 5, 2005 | 11:19 AM
Default Re: Clutch is stuck to the floor? (-Gambit-)
this is gonna sound retarded, but what fluid is used for the clutch?
Old Nov 5, 2005 | 11:21 AM
-Gambit-'s Avatar
brake fluid.
Old Nov 5, 2005 | 11:24 AM
k thought so
Old Nov 5, 2005 | 11:25 AM
::MYCORD::'s Avatar
Yeah you might be leaking brake fluid from your slave master cylinder. But once you put in the fluid, your clutch pedal should be ok
Old Nov 5, 2005 | 11:33 AM
Default Re: Clutch is stuck to the floor? (mycord)
hey 1 more question...
on the EG's i have 2 seperate Resoivoirs for Brake Fluid, the one big one, and then the one closer to the fender which is smaller and has a braided line that runs into the Firewall
the big one is Full, the but the small one doesnt have a fill line, and seems to be low or empty, is that the one for the clutch?
Old Nov 5, 2005 | 11:35 AM
-Gambit-'s Avatar
the small one is for the clutch the big one is brakes.
Old Nov 5, 2005 | 11:42 AM
Sean Juan's Avatar
Just fill the little one up somewhat close to the top. have someone pump it then hold the pedal in, then open the line on the front of the transmission to allow the air to leak out. repeat and keep checking that reservoir. it will go down as the air leaves the lines. make sure u keep it filled.
Old Nov 5, 2005 | 11:47 AM
Default Re: Clutch is stuck to the floor? (GRIP KING)
^ k i filled it nearly to the top and pumped it, but it seems to have like no pressure, it still sticks to the floor if i dont pull it back up
also, what am i looking for for this line on the front of the tranny? is it the same braided line that runs from the resoivor?
Old Nov 5, 2005 | 12:03 PM
eastbay925's Avatar
if the fluid is getting low then you probably have a leak, check all the lines and check that the master isn't leaking inside the car, and yes the line in front of the tranny goes to the slave sylinder wich is were the bleeder is
Old Nov 5, 2005 | 12:11 PM
marshun's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sniperslayer &raquo;</TD></TR><TR><TD CLASS="quote">^ k i filled it nearly to the top and pumped it, but it seems to have like no pressure, it still sticks to the floor if i dont pull it back up
also, what am i looking for for this line on the front of the tranny? is it the same braided line that runs from the resoivor?</TD></TR></TABLE>
so you bled the lines? cause if it leaked and went too low then you have air in there for sure.
the line in front of your tranny will be a hard steel line. theres a bleed valve on it. i guess you didnt bleed your lines after you put in the fluid
get a repair manual for your car and it'll have the steps. plus you'll have it for reference when something else goes wrong. thats IF
Default Re: Clutch is stuck to the floor? (eastbay925)
where would i be seeing it leaking inside the car?
Old Nov 5, 2005 | 12:15 PM
Kamin's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sniperslayer &raquo;</TD></TR><TR><TD CLASS="quote">where would i be seeing it leaking inside the car?</TD></TR></TABLE>
follow your clutch pedal up and look for fluid.
if thats dry, add some fluid to the resivor, pump the clutch a ton of times then go follow the line from the master to the slave and look for the leak.
odds are its a rubber portion of the line or a seal that went somewhere, should be obvious.
Old Nov 5, 2005 | 12:40 PM
EH-3's Avatar
slave cylinder
Old Nov 5, 2005 | 12:45 PM
Default Re: Clutch is stuck to the floor? (ridinonblades)
k...i looked at every line, inside the car etc. and no leaks?!?
so then how the expletive did i lose so much fluid?
Old Nov 5, 2005 | 12:50 PM
Kamin's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sniperslayer &raquo;</TD></TR><TR><TD CLASS="quote">k...i looked at every line, inside the car etc. and no leaks?!?
so then how the expletive did i lose so much fluid?</TD></TR></TABLE>
there is a leak.
Old Nov 5, 2005 | 06:29 PM
marshun's Avatar
there has to be fluid going into the master cylinder. you HAVE to bleed it to find out where the leak is
but since you dont see it in the cabin or on the fire wall, im guessing your slave cylinder might've died.
ray.riddler92
May 4, 2011 01:00 PM
pootelytoot
Classic Hondas
11
Feb 25, 2008 07:41 AM
redline7
Feb 17, 2008 12:24 PM
tytyguy
Dec 3, 2005 02:32 AM
mr.tom
Sep 19, 2005 06:14 PM
