5th gens with HIDs: i got a question for you
have any of you ever had HIDs with and without projectors? i'm trying to find out how non-projector HIDs perform against projector HIDs. i want to get HIDs but i don't want to hack up my headlights to fit the projectors. do they still have the cutoff line HIDs are known for? hows the light/color look? i will probably go with something around 5000k in terms of color. i thought there was a post about headlights without projectors a while ago, but i can't find it, so sorry if it is still out there somewhere. thanks.
Non-projector HIDs are terrible and blind people. That's the reason for the regulations against them. Just do the retrofit, it's not hard.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The Phil »</TD></TR><TR><TD CLASS="quote">Non-projector HIDs are terrible and blind people. That's the reason for the regulations against them. Just do the retrofit, it's not hard.</TD></TR></TABLE>
Damn, beat me to it....Defenitly do a retrofit, cause the lighting is way better than just putting HIDs in without projectors..As a matter of fact, I do retrofits for people. If you're interested, just IM me
not true at all, i have HIDs w/out projectors and they work prefectly, just make sure you adjust your beam pattern on them. mine are 8000k sylvania ballasts
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by khalal538 »</TD></TR><TR><TD CLASS="quote">
not true at all, i have HIDs w/out projectors and they work prefectly, just make sure you adjust your beam pattern on them. mine are 8000k sylvania ballasts</TD></TR></TABLE>
still causes alot of glare and hot spots onto the street....
...and how do you adjust your beam pattern with a freeform housing?
It's not a matter of them functioning or not, the kits are illegal and for good reason. Someone post up the picture of the HIDs in halogen housings shining on a wall, that shows it perfectly.
i have never heard of any regulation. i finally found some pictures of headlights without projectors, and i don't really like that look, there is a LOT of glare from what i can tell. looks like i will retro-fit some projectors along with the HIDs. i have a write up i found that i will be using. thanks for your input guys!
thelonerangers
23
Aug 30, 2005 02:00 PM
B and B
Jul 26, 2003 10:12 PM
