digital gauge cluster
Anyone know of a digital gauge cluster being put into a civic? I have been searching all week and have had no luck!!! I looked at the SARD stack meters but they are very hard on the wallet$$$$! Anyway any informantion would be great thanks!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkoundrelUSA »</TD></TR><TR><TD CLASS="quote">Try a search for "S2000 cluster"</TD></TR></TABLE>
No one has ever gotton the speedo to work.
yeah the s2000 cluster is clean as hell but like you have said i donk know of anyone that has gotten it to work right. No one that i talk to can give me a straight answer. I would love to do it but from what i can tell its next to impossible. If anyone knows of a write up on it or something that would be nice, but i haven't seen a speedo working yet. What other optins are there???
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bartman201 »</TD></TR><TR><TD CLASS="quote">yes someone did get it to work do a search.</TD></TR></TABLE>
Prove it. I've talked with several people with a lot of knowledge on this swap, and they have not been able to get it to work in an EG.
You can get it to work if you use the VSS from a K-series, proplem then is your ECU cant read the signal. theres a work in progress for a chip to covert the analog to digital for the cluster to work properly.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nocturnaldragon »</TD></TR><TR><TD CLASS="quote">You can get it to work if you use the VSS from a K-series, proplem then is your ECU cant read the signal. theres a work in progress for a chip to covert the analog to digital for the cluster to work properly.</TD></TR></TABLE>
Besides VTEC, what else does the ECU use the VSS signal for?
Adi
Adi
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike93eh »</TD></TR><TR><TD CLASS="quote">just get a apexi rev/speed meter off ebay for $30 like i did...</TD></TR></TABLE>
You would just tap that into your VSS, right?
$30?! I see them on there for well over $100.
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GRIP KING »</TD></TR><TR><TD CLASS="quote">$30?! I see them on there for well over $100.</TD></TR></TABLE>
for the older version..
here is the one i got for $30...
http://cgi.ebay.com/ebaymotors...ZWDVW
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM-EJ1 »</TD></TR><TR><TD CLASS="quote">You would just tap that into your VSS, right?</TD></TR></TABLE>
yes it has digital mph, rpms, and a bunch of other features..
Prove it. I've talked with several people with a lot of knowledge on this swap, and they have not been able to get it to work in an EG.</TD></TR></TABLE>
you need to talk to someone else then
http://www.marklamond.co.uk/pr...0.htm
http://www.marklamond.co.uk/pr...0.htm</TD></TR></TABLE>
Never heard of anyone doing it on Honda-Tech though.
Never heard of anyone doing it on Honda-Tech though.</TD></TR></TABLE>
matt is a honda-tech user. ill find the post
here you go
https://honda-tech.com/zerothread?id=1180369
here you go
1999CivicSi
Jul 27, 2005 09:03 PM
