s2000 gauge cluster ques.????
do you think a s2000 gauge cluster would fit in 1999 civic si...if it wont which i dont think it does........does anyone know what type of modification would have to be done if its possible to make it fit?? thanks
Re: s2000 gauge cluster ques.???? (1999CivicSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1999CivicSi »</TD></TR><TR><TD CLASS="quote">do you think a s2000 gauge cluster would fit in 1999 civic si...if it wont which i dont think it does........does anyone know what type of modification would have to be done if its possible to make it fit?? thanks</TD></TR></TABLE>
Its more than just a fitment iss with that cluster.
Do a search, there was a good thread a little bit ago on this swap.
It can be done, and I am SURE there is a thread about it...matter of fact I know I made one personally a few months ago. Do a search next time.
grammer nawzi
Re: (1999CivicSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1999CivicSi »</TD></TR><TR><TD CLASS="quote">thanks..keep some info coming</TD></TR></TABLE>
Are you retarded? SEARCH!!!! That's the info, period.
Re: (sicky)
theres no need to be an ******* about it, if you dont know dont post..simple..i did look and i couldnt find anything and it would be easier if someone knew the link to the thread or any website that explains it
grammer nawzi
Do you care if your speedometer works or not? The civic VSS puts out a different signal which the s2000 cluster doesn't pick up. I don't want to say that it is impossible to make it work, but you better be pretty damn smart with electronics.
Re: s2000 gauge cluster ques.???? (green00EX)
It's not only the speedometer, the temp guage nor the gas gauge work.....so basically....you will overheat and run out of gas all the time as well as not know how fast/slow you are going.
thanks for your help..looks like it seems quite impossible..but does anyone know anywhere to get digital gauges or a knock off version of the s2000 gauges that would fit a 99 si
b18c-ivic_gsR
23
08-29-2006 06:01 PM
