Ball joint removal for CV axle removal help.
Old Nov 5, 2005 | 06:50 AM
Narcoleptic's Avatar
Default Ball joint removal for CV axle removal help.
I'm trying to remove the CV axles from a 1991 Accord, and to do that you have to remove the ball joint from the knuckle. That is where my problem is. I've done a search and come up with some methods, but none of them seem to be working. My last try was the method described in the auto-to-manual swap in the "Guide to basic Accords" thread. The arm just rises with the knuckle. I've also tried using a gear puller on the "tangs" cast into the lower arm. The puller arms just slip off.
Is there another way? Can I unbolt the lower arm at its inner point on the body? Will I need an alignment after that? Any help is appreciated.
Edit: Nevermind, I think I just found the answer:
http://www.overboost.com/pix.a...4.jpg
I had one of those tools in my hand last night when I was leaving the parts store. Instead I rented a 2/3 jaw puller. Now I feel like a retard.
Modified by Narcoleptic at 8:17 AM 11/5/2005
Old Nov 5, 2005 | 08:21 PM
213374U's Avatar
0x5359-0055
Community Builder
Default Re: Ball joint removal for CV axle removal help. (Narcoleptic)
Note for anyone with this similar problem.....
Pickel fork and a baby sledge hammer
Old Nov 6, 2005 | 10:50 PM
accordredliner's Avatar
* B A N N E D *
wedge a large pry bar between the LCA and the Knuckle and hit the pry bar with a large hammer. Puller failed me but this method has not.
Old Nov 7, 2005 | 09:39 AM
213374U's Avatar
0x5359-0055
Community Builder
Default Re: (accordredliner)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by accordredliner &raquo;</TD></TR><TR><TD CLASS="quote">wedge a large pry bar between the LCA and the Knuckle and hit the pry bar with a large hammer. Puller failed me but this method has not.</TD></TR></TABLE>
original post
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vt4cPwn35 &raquo;</TD></TR><TR><TD CLASS="quote">Note for anyone with this similar problem.....
Pickel fork and a baby sledge hammer </TD></TR></TABLE>
Old Nov 7, 2005 | 12:28 PM
* B A N N E D *
Default Re: (Vt4cPwn35)
original post
your method would bust the boot. What i described wil not
Old Nov 7, 2005 | 12:30 PM
213374U's Avatar
0x5359-0055
Community Builder
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by accordredliner &raquo;</TD></TR><TR><TD CLASS="quote">your method would bust the boot. What i described wil not</TD></TR></TABLE>
It's the same damn thing!!!! And I've yet to "bust the boot"
Old Nov 7, 2005 | 12:32 PM
* B A N N E D *
the chances of u ruining the boot will be greater if u use a fork. Ask anybody.
Old Nov 7, 2005 | 12:48 PM
raceACCORDingly's Avatar
this is the easiest and safest way. doesnt even touch the boot.
http://www.we-todd-did-racing....5NTQx
Old Nov 7, 2005 | 02:46 PM
Sehc Tib Alli Zerif!!!!!'s Avatar
cool guy name
Default Re: (raceACCORDingly)
been doing it this way for a while now
Old Nov 7, 2005 | 07:16 PM
word. gravity at its finest.
White_EG1
22
May 21, 2018 10:20 AM
Alcatrax30
Nov 9, 2014 05:38 AM
usdmEHboy
10
Feb 4, 2009 10:27 PM
hondaEg_808
Nov 27, 2008 04:22 PM
C_Rock77
Aug 27, 2008 11:19 AM
