Lost motion assembly?? ... does the head need to come off?
Old Nov 5, 2005 | 04:59 AM
Firestarter's Avatar
Default Lost motion assembly?? ... does the head need to come off?
does the head have to come off when the lost motion assemblies are being replaced in a b16a motor?
Old Nov 5, 2005 | 05:06 AM
NJIN BUILDR's Avatar
Default Re: Lost motion assembly?? ... does the head need to come off? (Firestarter)
Well almost.The cam has to come out and that requires removing the head bolts.
Glenn
Old Nov 5, 2005 | 06:41 AM
non-VTEC's Avatar
Default Re: Lost motion assembly?? ... does the head need to come off? (NJIN BUILDR)
no the head does not have to come off and you dont have to remove the headbolts............its still quite a bit of work though
Old Nov 5, 2005 | 08:30 AM
Default Re: Lost motion assembly?? ... does the head need to come off? (non-VTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by non-VTEC &raquo;</TD></TR><TR><TD CLASS="quote">no the head does not have to come off and you dont have to remove the headbolts............its still quite a bit of work though</TD></TR></TABLE>
My bad on the head bolts.Removing head bolts requires removing cams on vtec b , not the other way around.Anyway the rocker shafts and rockers have to be removed to get the LMA's out.Even with the rockers flipped up there is not enough room to get them past.The shafts are as long as the head and I'm not sure they can be removed in the car.I've removed the head to do them before.
Glenn
Old Nov 5, 2005 | 01:30 PM
k24em2's Avatar
If you pull them out above the transmission you should be able to get the rocker shafts out.
Pippen_001
Oct 28, 2008 12:00 PM
91preyludesi
Nov 18, 2005 07:21 AM
89dxhunchback
Jan 13, 2005 01:53 PM
hoggy
Jul 1, 2004 12:03 PM
B_CRUZ!
Jan 10, 2002 10:49 PM
